storage tape show-tape-drive
Display information about tape drives
This storage tape show-tape-drive
command displays information about tape drives attached to the cluster. By default, this command displays the following information about all tape drives:
Device ID of tape drive
Description of tape drive
World Wide Node Name of tape drive
World Wide Port Name of tape drive
Serial Number of tape drive
Tape drive errors
Node to which the tape drive is attached
Initiator port which hosts the tape drive
Alias name of tape drive
Operational state of tape drive
Functional status of tape drive
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-device-id <text>]
- Device ID-
Selects the tape drive with the specified device ID.
[-node {<nodename>|local}]
- Node-
Displays detailed information about tape drives on the specified node.
[-description <text>]
- Description-
Selects the tape drives with the specified description.
[-alias-name <text>]
- Alias Name-
Selects the tape drive with the specified alias name.
[-wwnn <text>]
- World Wide Node Name-
Selects the tape drives with the specified World Wide Node Name.
[-wwpn <text>]
- World Wide Port Name-
Selects the tape drive with the specified World Wide Port Name.
[-serial-number <text>]
- Serial Number-
Selects the tape drive with the specified serial number.
[-device-if-type {unknown|fibre-channel|SAS|pSCSI}]
- Device If Type-
Selects the tape drives with the specified interface type.
[-device-state {unknown|available|ready-write-enabled|ready-write-protected|offline|in-use|error|reserved-by-another-host|normal}]
- Operational State of Device-
Selects the tape drives with the specified operational state.
[-error <text>]
- Tape Drive Error Description-
Selects the tape drives with the specified error string.
[-initiator <text>]
- Initiator Port-
Selects the tape drives with the specified initiator port.
[-resv-type {off|persistent|scsi}]
- Reservation type for device-
Selects the tape drives with the specified type.
The following example displays information about all tape drives attached to the cluster:
cluster1::> storage tape show-tape-drive Tape Drive: sw4:11.126 Description: StorageTek T10000C WWNN: 5:001:04f000:b39ec8 WWPN: 5:001:04f000:b39ec9 Serial Number: 576004000041 Errors: - Paths: Node Initiator Alias Device State Status ------------------------ --------- ------- ------------------------ -------- cluster1-01 2a st0 ready-write-enabled normal Tape Drive: sw4:12.4 Description: HP LTO-3 WWNN: 2:001:000e11:10b919 WWPN: 2:002:000e11:10b919 Serial Number: 1068000371 Errors: - Paths: Node Initiator Alias Device State Status ------------------------ --------- ------- ------------------------ -------- cluster1-01 0b st1 ready-write-enabled normal
