storage tape show-tape-drive
Display information about tape drives
This storage tape show-tape-drive command displays information about tape drives attached to the cluster. By default, this command displays the following information about all tape drives:
Device ID of tape drive
Description of tape drive
World Wide Node Name of tape drive
World Wide Port Name of tape drive
Serial Number of tape drive
Tape drive errors
Node to which the tape drive is attached
Initiator port which hosts the tape drive
Alias name of tape drive
Operational state of tape drive
Functional status of tape drive
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-device-id <text>]- Device ID-
Selects the tape drive with the specified device ID.
 [-node {<nodename>|local}]- Node-
Displays detailed information about tape drives on the specified node.
 [-description <text>]- Description-
Selects the tape drives with the specified description.
 [-alias-name <text>]- Alias Name-
Selects the tape drive with the specified alias name.
 [-wwnn <text>]- World Wide Node Name-
Selects the tape drives with the specified World Wide Node Name.
 [-wwpn <text>]- World Wide Port Name-
Selects the tape drive with the specified World Wide Port Name.
 [-serial-number <text>]- Serial Number-
Selects the tape drive with the specified serial number.
 [-device-if-type {unknown|fibre-channel|SAS|pSCSI}]- Device If Type-
Selects the tape drives with the specified interface type.
 [-device-state {unknown|available|ready-write-enabled|ready-write-protected|offline|in-use|error|reserved-by-another-host|normal}]- Operational State of Device-
Selects the tape drives with the specified operational state.
 [-error <text>]- Tape Drive Error Description-
Selects the tape drives with the specified error string.
 [-initiator <text>]- Initiator Port-
Selects the tape drives with the specified initiator port.
 [-resv-type {off|persistent|scsi}]- Reservation type for device-
Selects the tape drives with the specified type.
The following example displays information about all tape drives attached to the cluster:
cluster1::> storage tape show-tape-drive
Tape Drive: sw4:11.126
  Description: StorageTek T10000C
         WWNN: 5:001:04f000:b39ec8
         WWPN: 5:001:04f000:b39ec9
Serial Number: 576004000041
Errors: -
Paths:
Node                      Initiator  Alias    Device State              Status
cluster1-01               2a         st0      ready-write-enabled       normal
Tape Drive: sw4:12.4
  Description: HP LTO-3
         WWNN: 2:001:000e11:10b919
         WWPN: 2:002:000e11:10b919
Serial Number: 1068000371
Errors: -
Paths:
cluster1-01               0b         st1      ready-write-enabled       normal
