volume snaplock show
Display SnapLock attributes of a SnapLock volume
The ` volume snaplock show ` command displays following information :
  • Vserver name
  • Volume name
  • SnapLock Type of the volume
  • Minimum retention period applicable of the volume
  • Default retention period applicable of the volume
  • Maximum retention period applicable of the volume
  • Autocommit period of the volume
  • Volume Append Mode attribute of the volume
  • Privileged Delete attribute of the volume
  • Litigation count on the volume
  • Volume expiry time of the volume
  • Volume ComplianceClock
  • SnapLock audit log volume
  • Unspecified retention file count on the volume
This command is applicable only for SnapLock volumes.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
If this parameter is specified, the command displays information for all the SnapLock volumes that match the specified -vserver value.
[-volume <volume name>] - Volume
If this parameter is specified, the command displays information for the specified -volume value.
[-type {non-snaplock|compliance|enterprise}] - SnapLock Type
If this parameter is specified, the command displays all the volumes that match the specified -type value.
[-minimum-retention-period {{<integer> seconds|minutes|hours|days|months|years} | infinite}] - Minimum Retention Period
If this parameter is specified, the command displays all the volumes that match the specified -minimum-retention-period value.
[-default-retention-period {{<integer> seconds|minutes|hours|days|months|years} | min | max | infinite | unspecified}] - Default Retention Period
If this parameter is specified, the command displays all the volumes that match the specified -default-retention-period value.
[-maximum-retention-period {{<integer> seconds|minutes|hours|days|months|years} | infinite}] - Maximum Retention Period
If this parameter is specified, the command displays all the volumes that match the specified -maximum-retention-period value.
[-autocommit-period {{<integer> minutes|hours|days|months|years} | none}] - Autocommit Period
If this parameter is specified, the command displays all the volumes that match the specified -autocommit-period value.
[-is-volume-append-mode-enabled {true|false}] - Is Volume Append Mode Enabled
If this parameter is specified, the command displays all the volumes that match the specified -is-volume-append-mode-enabled value.
[-privileged-delete {disabled|enabled|permanently-disabled}] - Privileged Delete
If this parameter is specified, the command displays all the volumes that match the specified -privileged-delete value.
[-expiry-time <text>] - Expiry Time
If this parameter is specified, the command displays all the volumes that match the specified -expiry-time value.
[-compliance-clock-time <text>] - ComplianceClock Time
If this parameter is specified, the command displays all the volumes that match the specified -compliance-clock-time value.
[-litigation-count <integer>] - Litigation Count
If this parameter is specified, the command displays all the volumes that match the specified -litigation-count value.
[-is-audit-log-volume {true|false}] - Is SnapLock Audit Log Volume
If this parameter is specified, the command displays all the volumes that match the specified -is-audit-log-volume value.
[-unspecified-retention-file-count <integer>] - Unspecified Retention File Count
If this parameter is specified, the command displays all the volumes that match the specified -unspecified-retention-file-count value.
The following command shows summary of SnapLock volumes on a vserver:
cluster1::> volume snaplock show
Vserver       Volume          SnapLock Type ComplianceClock Time
vs1           vol_slc         compliance    Mon Jan 19 14:12:34 IST 2015 +05:30
vs1           vol_sle         enterprise    Mon Jan 19 14:12:34 IST 2015 +05:30
2 entries were displayed.
cluster1::>
The following commands lists the complete SnapLock attributes of two given SnapLock volumes:
cluster1::> volume snaplock show -vserver vs1 -volume vol_slc
Vserver Name: vs1
                      Volume Name: vol_slc
                    SnapLock Type: compliance
         Minimum Retention Period: 1 years
         Default Retention Period: max
         Maximum Retention Period: 30 years
                Autocommit Period: 12 hours
    Is Volume Append Mode Enabled: false
                Privileged Delete: permanently-disabled
                      Expiry Time: Thu May 11 14:37:21 GMT 2017
             ComplianceClock Time: Wed May 11 20:08:41 IST 2016 +05:30
                 Litigation Count: 0
     Is SnapLock Audit Log Volume: false
     Unspecified Retention File Count: 0
cluster1::>
cluster1::> volume snaplock show -vserver vs1 -volume vol_sle
Vserver Name: vs1
                      Volume Name: vol_sle
                    SnapLock Type: enterprise
         Minimum Retention Period: 6 months
         Default Retention Period: min
         Maximum Retention Period: infinite
                Autocommit Period: none
                Privileged Delete: enabled
                      Expiry Time: infinite
             ComplianceClock Time: Wed May 11 20:08:44 IST 2016 +05:30
                 Litigation Count: 0
