job show
Display a list of jobs
The job show
command displays information about jobs. By default, the command displays information about all current jobs.
To display detailed information about a specific job, run the command with the -id
parameter.
You can specify additional parameters to select information that matches the values you specify for those parameters. For example, to display information only about jobs running on a specific node, run the command with the -node
parameter.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-inprogress ]
Displays the job ID, the job name, the owning Vserver, and the progress of the job.
[-jobstate ]
Displays information about each job’s state, including the queue state, whether the job was restarted, and when the job has completely timed out.
[-sched ]
Displays the job ID, the job name, the owning Vserver, and the schedule on which the job runs.
[-times ]
Displays the job ID, the job name, the owning Vserver, the time when the job was last queued, the time when the job was last started, and the time when the job most recently ended.
[-type ]
Displays the job ID, the job name, the job type, and the job category.
[-jobuuid ]
Displays the job ID, the job name, the owning Vserver, and the job UUID.
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-id <integer>]
- Job ID-
Selects the jobs that match the ID or range of IDs that you specify.
[-vserver <vserver name>]
- Owning Vserver-
Selects jobs that are owned by the specified Vserver.
[-name <text>]
- Name-
Selects the jobs that match this parameter value.
[-description <text>]
- Description-
[-priority {Low|Medium|High|Exclusive}]
- Priority-
[-node <nodename>]
- Node-
[-affinity {Cluster|Node}]
- Affinity-
[-schedule <job_schedule>]
- Schedule-
[-queuetime <MM/DD HH:MM:SS>]
- Queue Time-
[-starttime <MM/DD HH:MM:SS>]
- Start Time-
[-endtime <MM/DD HH:MM:SS>]
- End Time-
[-dropdeadtime <MM/DD HH:MM:SS>]
- Drop-dead Time-
[-restarted {true|false}]
- Restarted?-
[-state {Initial|Queued|Running|Waiting|Pausing|Paused|Quitting|Success|Failure|Reschedule|Error|Quit|Dead|Unknown|Restart|Dormant}]
- State-
[-code <integer>]
- Status Code-
[-completion <text>]
- Completion String-
[-jobtype <text>]
- Job Type-
[-category <text>]
- Job Category-
[-uuid <UUID>]
- UUID-
[-progress <text>]
- Execution Progress-
[-username <text>]
- User Name-
[-restart-is-delayed-by-module <text>]
- Restart Is Delayed by Module-
Selects jobs which are or were delayed by the specified module during the restart. For example: MCC_SWITCHBACK
The following example displays information about all jobs on the node named node1:
cluster1::> job show -node node1 Owning Job ID Name Vserver Node State ------ ---------------- --------- ------------ ---------- 308114 mirror-daily-3587206 node-vserver node1 Running Descr:Auto-replicate to 1 mirror(s) 308115 mirror-daily-3618985 node-vserver node1 Running Descr:Auto-replicate to 1 mirror(s) 308116 mirror-daily-3619010 node-vserver node1 Queued Descr:Auto-replicate to 1 mirror(s) 308117 mirror-daily-3749547 node-vserver node1 Queued Descr:Auto-replicate to 1 mirror(s) 4 entries were displayed.
