Command reference
job show
Display a list of jobs
The job show command displays information about jobs. By default, the command displays information about all current jobs.
To display detailed information about a specific job, run the command with the -id parameter.
You can specify additional parameters to select information that matches the values you specify for those parameters. For example, to display information only about jobs running on a specific node, run the command with the -node parameter.
{ [-fields <fieldname>,…​]
| [-inprogress ]
Displays the job ID, the job name, the owning Vserver, and the progress of the job.
| [-jobstate ]
Displays information about each job's state, including the queue state, whether the job was restarted, and when the job has completely timed out.
| [-jobuuid ] (privilege: advanced)
Displays the job ID, the job name, the owning Vserver, and the job UUID.
| [-sched ]
Displays the job ID, the job name, the owning Vserver, and the schedule on which the job runs.
| [-times ]
Displays the job ID, the job name, the owning Vserver, the time when the job was last queued, the time when the job was last started, and the time when the job most recently ended.
| [-type ]
Displays the job ID, the job name, the job type, and the job category.
| [-instance ] }
[-id <integer>] - Job ID
Selects the jobs that match the ID or range of IDs that you specify.
[-vserver <vserver name>] - Owning Vserver
Selects jobs that are owned by the specified Vserver.
[-name <text>] - Name
Selects the jobs that match this parameter value.
[-description <text>] - Description
[-priority {Low|Medium|High|Exclusive}] - Priority
[-node <nodename>] - Node
[-affinity {Cluster|Node}] - Affinity
[-schedule <job_schedule>] - Schedule
[-queuetime <MM/DD HH:MM:SS>] - Queue Time
[-starttime <MM/DD HH:MM:SS>] - Start Time
[-endtime <MM/DD HH:MM:SS>] - End Time
[-dropdeadtime <MM/DD HH:MM:SS>] - Drop-dead Time
[-restarted {true|false}] - Restarted?
[-state {Initial|Queued|Running|Waiting|Pausing|Paused|Quitting|Success|Failure|Reschedule|Error|Quit|Dead|Unknown|Restart|Dormant}] - State
[-code <integer>] - Status Code
[-completion <text>] - Completion String
[-jobtype <text>] - Job Type
[-category <text>] - Job Category
[-uuid <UUID>] - UUID (privilege: advanced)
[-progress <text>] - Execution Progress
[-username <text>] - User Name
[-restart-is-delayed-by-module <text>] - Restart Is Delayed by Module
Selects jobs which are or were delayed by the specified module during the restart. For example: MCC_SWITCHBACK
The following example displays information about all jobs on the node named node1:
cluster1::> job show -node node1
                        Owning
Job ID Name             Vserver   Node         State
308114 mirror-daily-3587206
                        node-vserver
                                  node1        Running
       Descr:Auto-replicate to 1 mirror(s)
308115 mirror-daily-3618985
                        node-vserver
                                  node1        Running
308116 mirror-daily-3619010
                        node-vserver
                                  node1        Queued
308117 mirror-daily-3749547
                        node-vserver
                                  node1        Queued
4 entries were displayed.
