vserver nvme namespace show
Display NVMe namespaces
The vserver nvme namespace show
command displays information for NVMe namespaces.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver Name-
Use this parameter to display the NVMe namespaces that match the Vserver that you specify.
[-path <path>]
- Namespace Path-
Use this parameter to display the NVMe namespace that matches the path that you specify.
[-size {<integer>[KB|MB|GB|TB|PB]}]
- Size-
Use this parameter to display the NVMe namespaces that match the size that you specify.
[-size-used {<integer>[KB|MB|GB|TB|PB]}]
- Size Used-
Use this parameter to display the NVMe namespaces that match this parameter value.
[-ostype {aix|linux|vmware|windows}]
- OS Type-
[-comment <text>]
- Comment-
[-block-size {512|4KB}]
- Block Size-
[-state {online|offline|nvfail|space-error}]
- State-
[-is-read-only {true|false}]
- Is Read Only-
[-creation-timestamp <MM/DD/YYYY HH:MM:SS>]
- Creation Time-
[-uuid <UUID>]
- Namespace UUID-
[-restore-inaccessible {true|false}]
- Restore Inaccessible-
[-node <nodename>]
- Node Hosting the Namespace-
[-volume <volume name>]
- Volume Name-
[-qtree <qtree name>]
- Qtree Name-
[-subsystem <text>]
- Mapped Subsystem-
Use this parameter to display the NVMe namespaces that are attached to a Subsystem that matches this parameter value.
[-nsid <Hex 32bit Integer>]
- Namespace ID-
[-anagrpid <Hex 32bit Integer>]
- ANA Group ID-
Use this parameter to display the NVMe namespaces that match Asymmetric Namespace Access (ANA) group identifier that you specify.
[-vserver-id <integer>]
- Vserver ID-
[-container-state {online|aggregate-offline|volume-offline|error}]
- Namespace Container State-
Selects the namespaces that match this parameter value. The container states are:
online
- The namespace’s aggregate and volume are online. -
aggregate-offline
- The namespace’s aggregate is offline. -
volume-offline
- The namespace’s volume is offline. -
error
- An error occurred accessing the namespace’s volume.
[-include-offline-containers <true>]
- Include Namespaces on Offline Volumes and Aggregates-
If true, include available information for namespaces in offline aggregates and offline volumes in the output. By default, namespaces in offline aggregates and offline volumes are excluded from the output.
[-application <text>]
- Application-
Selects the namespace that are part of an application that matches the parameter value.
cluster::*> vserver nvme namespace show -vserver vs1 Vserver Path State Size Subsystem NSID --------- ------------------------------- ------- ------ ---------- --------- vs1 /vol/test_1_vol/ns1 online 10GB subsys1 00000001h vs1 /vol/test_1_vol/ns2 online 500MB subsys1 00000002h vs1 /vol/test_1_vol/ns3 online 1TB - - 3 entries were displayed.
