vserver peer transition modify
Modify a transition peer relationship.
The vserver peer transition modify
command is used to modify the multipath address or local LIFs of the transition peer relationship.
-local-vserver <vserver name>
- Local Vserver name-
Specifies the name of the local Vserver.
-src-filer-name <text>
- Source 7-Mode system-
Specifies the name of the source 7-Mode system (hostname or IP address).
[-multi-path-address <text>]
- Additional address for source 7-Mode system-
Additional address (hostname or IP address) for the source 7-Mode system.
[-local-lifs <lif-name>,…]
- List of Local LIFs-
List of LIFs to be used for this peering relationship. The LIF role can be data or node-mgmt or intercluster or cluster-mgmt.
The following example illustrates how to modify a transition peer relationship`s multipath address.
cluster1::> vserver peer transition modify -local-vserver vs1.example.com -src-filer-name src1.example.com -multi-path-address src1-e0b.example.com
The following example illustrates how to modify the local LIFs of a transition peer relationship.
Cluster1::> vserver peer transition modify -local-vserver vs1.example.com -src-filer-name src1.example.com -local-lifs lif1,lif2
