security session limit application modify
Modify per-application session limit
This command allows modification of a per-application management session limit.
-interface {cli|ontapi|rest}
- Interface (privilege: advanced)-
The interface (CLI, ONTAPI, or REST) to which the limit applies.
-application <text>
- Application (privilege: advanced)-
The specified application to which this limit applies. The limit with the application name
-default-
is the limit used for any application without a specific configured limit. [-max-active-limit <integer>]
- Max-Active Limit (privilege: advanced)-
The maximum number of concurrent sessions allowed for this interface and application.
The following example illustrates modifying management session limits for some custom applications.
cluster1::*> security session limit application modify -interface ontapi -application custom* -max-active-limit 4 2 entries were modified.
