ONTAP 9.9.1 commands
security session limit application modify
Modify per-application session limit
This command allows modification of a per-application management session limit.
-interface {cli|ontapi|rest} - Interface (privilege: advanced)
The interface (CLI, ONTAPI, or REST) to which the limit applies.
-application <text> - Application (privilege: advanced)
The specified application to which this limit applies. The limit with the application name -default- is the limit used for any application without a specific configured limit.
[-max-active-limit <integer>] - Max-Active Limit (privilege: advanced)
The maximum number of concurrent sessions allowed for this interface and application.
The following example illustrates modifying management session limits for some custom applications.
cluster1::*> security session limit application modify -interface ontapi -application custom* -max-active-limit 4
2 entries were modified.
