storage shelf acp configure
Configure alternate control path (ACP)
Configure the ACP connectivity on the cluster.
-is-enabled {true|false} - Is Enabled?
Configures the connectivity to the specified state.
[-subnet <IP Address>] - Subnet
Configures the connectivity to the specified subnet.
[-netmask <IP Address>] - Netmask
Configures the connectivity to the specified netmask.
[-channel {out-of-band|in-band}] - Channel
Configures the connectivity to the specified channel.
The following example configures out-of-band ACP connectivity on each node:
cluster1::> storage shelf acp configure -is-enabled true -channel out-of-band -subnet 192.168.0.1 -netmask 255.255.255.0
The following example configures in-band ACP connectivity on each node:
cluster1::> storage shelf acp configure -is-enabled true -channel in-band
The following example disables ACP connectivity on each node:
cluster1::> storage shelf acp configure -is-enabled false
