storage disk updatefirmware
(DEPRECATED) - Update disk firmware
Note This command is deprecated and may be removed in a future release of Data ONTAP. Use the "storage disk firmware update " command.
The storage disk updatefirmware command updates the firmware on one or more disks.
You can download the latest firmware by using the storage firmware download command.
You can specify a list of one or more disks whose firmware is to be updated by using the -disk
parameter, or you can update the firmware on all local disks by omitting the -disk parameter.
[-disk <disk path name>,…​] - Disk
This specifies the disk or disks whose firmware is to be updated.
If you do not specify this option, all local disks' firmware is updated.
The following example updates the firmware on all disks:
cluster1::> storage disk updatefirmware
