system ha interconnect ood disable-optimization
Disable coalescing work requests
The system ha interconnect ood disable-optimization command disables the optimization capability on the high-availability interconnect device. The command is only supported on FAS2500 series nodes in the cluster.
-node <nodename> - Node
This mandatory parameter specifies which node will have the optimization disabled. The value "local" specifies the current node.
cluster1::*> system ha interconnect ood disable-optimization -node ic-f2554-03
