      security anti-ransomware volume workload-behavior update-baseline-from-surge
Set the observed surge values as the new baseline on a volume
The security anti-ransomware volume workload-behavior update-baseline-from-surge command sets the observed surge value as new baseline.
-vserver <vserver name>- Vserver Name-
This parameter specifies the Vserver on which the volume is located.
 -volume <volume name>- Volume Name-
This parameter specifies the name of the volume on which anti-ransomware feature is enabled.
cluster1::> security anti-ransomware volume workload-behavior show -vserver vs1 -volume vol1
                       Vserver                  : vs1
                       Volume                   : vol1
                       File Extensions Observed : .txt, .exe, .pdf, .img
             Number of File Extensions Observed : 4
Historical Statstics
  High Entropy Data Write Percentage            : 50
  High Entropy Data Write Peak Rate (KB/Minute) : 50
  File Create Peak Rate (per Minute)            : 100
  File Delete Peak Rate (per Minute)            : 100
  File Rename Peak Rate (per Minute)            : 100
Surge Observed
  Surge Timeline                                : 10/3/2021 14:01:00
  High Entropy Data Write Percentage            : 100
  High Entropy Data Write Peak Rate (KB/Minute) : 2000
  File Create Peak Rate (per Minute)            : 80
  File Delete Peak Rate (per Minute)            : -
  File Rename Peak Rate (per Minute)            : 200
  Newly Observed File Extensions                : .dll, .exec, .js
  Number of Newly Observed File Extensions      : 10, 4, 22
cluster1::> security anti-ransomware volume workload-behavior update-baseline-from-surge -vserver vs1 -volume vol1
                       Vserver                  : vs1
                       Volume                   : vol1
  File Create Peak Rate (per Minute)            : 180
Surge Observed
  Surge Timeline                                : -
  High Entropy Data Write Percentage            : -
  High Entropy Data Write Peak Rate (KB/Minute) : -
  File Create Peak Rate (per Minute)            : -
  File Rename Peak Rate (per Minute)            : -
