security ssl show
Display the SSL configuration for HTTP servers
This command displays the configuration of encrypted HTTP (SSL) for Vservers in the cluster. Depending on the requirements of the individual node’s or cluster’s web services (displayed by the vserver services web show command), this encryption might or might not be used. If the Vserver does not have a certificate associated with it, SSL will not be available.
{ [-fields <fieldname>,…​]
| [-ocsp ]
If you specify the -ocsp parameter, the command displays the Online Certificate Status Protocol configuration.
| [-instance ] }
[-vserver <Vserver Name>] - Vserver
Identifies a Vserver for hosting SSL-encrypted web services.
[-ca <text>] - Server Certificate Issuing CA
Filters the display of SSL configuration by specifying the Certificate Authority (CA) that issued the server certificate.
[-serial <text>] - Server Certificate Serial Number
Filters the display of SSL configuration by specifying the serial number of a server certificate.
[-common-name <FQDN or Custom Common Name>] - Server Certificate Common Name
Filters the display of SSL configuration by specifying the common name for the server certificate.
[-server-enabled {true|false}] - SSL Server Authentication Enabled
Filters the display of SSL configuration according to whether the SSL server authentication is enabled or disabled. Vservers have self-signed certificates automatically generated during their creation. These Vserver self-signed certificates are server-enabled by default.
[-client-enabled {true|false}] - SSL Client Authentication Enabled
Filters the display of SSL configuration according to whether the SSL client authentication is enabled or disabled. You can enable client authentication only when server authentication is enabled.
[-ocsp-enabled {true|false}] - Online Certificate Status Protocol Validation Enabled
Filters the display of SSL configuration when the Online Certificate Status Protocol validation is enabled.
[-ocsp-default-responder <text>] - URI of the Default Responder for OCSP Validation
Filters the display of SSL configuration according to the URI of the default responder for OCSP validation.
[-ocsp-override-responder {true|false}] - Force the Use of the Default Responder URI for OCSP Validation
Filters the display of SSL configuration, which forces the use of the default responder URI for OCSP validation.
[-ocsp-responder-timeout <[<integer>h][<integer>m][<integer>s]>] - Timeout for OCSP Queries
Filters the display of SSL configuration according to the timeout for queries to OCSP responders.
[-ocsp-max-response-age <unsigned32_or_unlimited>] - Maximum Allowable Age for OCSP Responses (secs)
Filters the display of SSL configuration according to the maximum allowable age (freshness) in seconds for the OCSP responses.
[-ocsp-max-response-time-skew <[<integer>h][<integer>m][<integer>s]>] - Maximum Allowable Time Skew for OCSP Response Validation
Filters the display of SSL configuration according to the maximum allowable time difference for OCSP responses (when validating their ThisUpdate and NextUpdate fields).
[-ocsp-use-request-nonce {true|false}] - Use a NONCE within OCSP Queries
Filters the display of SSL configuration by specifying whether the queries to the OCSP responders should contain a NONCE or not.
Note A NONCE is a unique identifier included in each OCSP request or OCSP response to prevent a replay attack.
The following example displays the configured certificates for Vservers.
cluster1::security ssl> show
          Serial                                         Server  Client
Vserver   Number Common Name                             Enabled Enabled
cluster1  516C3CB3
                 cluster1.company.com                    true    true
vs0       516816D4
                 vs0.company.com                         true    false
2 entries were displayed.
