system bridge config-dump show
Display a list of bridge dumpconfiguration files
The system bridge config-dump show
command displays information about all the dumpconfiguration files previously retrieved with the system bridge config-dump collect command. If no parameters are specified, the default command displays the following information about the dumpconfiguration files:
Node
File Name
Timestamp
Bridge
Bridge Serial Number
To display detailed information about a single dumpconfiguration file, use the -node
and -file
parameters.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Displays information about the dumpconfiguration files stored on the node that matches the specified node name.
[-file <text>]
- Config File-
Displays information about the dumpconfiguration files that match the specified file name.
[-bridge <text>]
- Bridge Name-
Displays information about the dumpconfiguration files from the bridge that matches the specified bridge name.
[-serial-number <text>]
- Serial Number of Bridge-
Displays information about the dumpconfiguration files from the bridge that matches the specified serial number.
[-timestamp <MM/DD/YYYY HH:MM:SS>]
- Time of Collection-
Displays information about the dumpconfiguration files that were collected at the specified time.
The following example displays information about all dumpconfiguration files:
cluster1::*> system bridge config-dump show Bridge: ATTO_FibreBridge7500N_1 Node File Name Timestamp ----- ----------------------------------------------------- ------------------- node1 dsbridge_config.FB7500N100001.2017-05-01_09_53_53.txt 5/1/2017 09:53:53 node2 dsbridge_config.FB7500N100001.2017-04-28_14_48_35.txt 4/28/2017 14:48:35 dsbridge_config.FB7500N100001.2017-04-28_15_50_20.txt 4/28/2017 15:50:20 3 entries were displayed. cluster1::*>
The following example displays detailed information about all dumpconfiguration files:
cluster1::*> system bridge config-dump show -instance Node: node1 Bridge Name: ATTO_FibreBridge7500N_1 Filename: dsbridge_config.FB7500N100001.2017-05-01_09_53_53.txt Timestamp: 5/1/2017 09:53:53 Bridge Serial Number: FB7500N100001 Node: node2 Bridge Name: ATTO_FibreBridge7500N_1 Filename: dsbridge_config.FB7500N100001.2017-04-28_14_48_35.txt Timestamp: 4/28/2017 14:48:35 Bridge Serial Number: FB7500N100001 Node: node2 Bridge Name: ATTO_FibreBridge7500N_1 Filename: dsbridge_config.FB7500N100001.2017-04-28_15_50_20.txt Timestamp: 4/28/2017 15:50:20 Bridge Serial Number: FB7500N100001 3 entries were displayed. cluster1::*>
