system bridge config-dump show
Display a list of bridge dumpconfiguration files
The system bridge config-dump show command displays information about all the dumpconfiguration files previously retrieved with the system bridge config-dump collect command. If no parameters are specified, the default command displays the following information about the dumpconfiguration files:
Node
File Name
Timestamp
Bridge
Bridge Serial Number
To display detailed information about a single dumpconfiguration file, use the -node and -file parameters.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node (privilege: advanced)-
Displays information about the dumpconfiguration files stored on the node that matches the specified node name.
[-file <text>]- Config File (privilege: advanced)-
Displays information about the dumpconfiguration files that match the specified file name.
[-bridge <text>]- Bridge Name (privilege: advanced)-
Displays information about the dumpconfiguration files from the bridge that matches the specified bridge name.
[-serial-number <text>]- Serial Number of Bridge (privilege: advanced)-
Displays information about the dumpconfiguration files from the bridge that matches the specified serial number.
[-timestamp <MM/DD/YYYY HH:MM:SS>]- Time of Collection (privilege: advanced)-
Displays information about the dumpconfiguration files that were collected at the specified time.
The following example displays information about all dumpconfiguration files:
cluster1::*> system bridge config-dump show
Bridge: ATTO_FibreBridge7500N_1
Node File Name Timestamp
node1
dsbridge_config.FB7500N100001.2017-05-01_09_53_53.txt 5/1/2017 09:53:53
node2
dsbridge_config.FB7500N100001.2017-04-28_14_48_35.txt 4/28/2017 14:48:35
dsbridge_config.FB7500N100001.2017-04-28_15_50_20.txt 4/28/2017 15:50:20
3 entries were displayed.
cluster1::*>
The following example displays detailed information about all dumpconfiguration files:
cluster1::*> system bridge config-dump show -instance
Node: node1
Bridge Name: ATTO_FibreBridge7500N_1
Filename: dsbridge_config.FB7500N100001.2017-05-01_09_53_53.txt
Timestamp: 5/1/2017 09:53:53
Bridge Serial Number: FB7500N100001
Node: node2
Filename: dsbridge_config.FB7500N100001.2017-04-28_14_48_35.txt
Timestamp: 4/28/2017 14:48:35
Node: node2
Filename: dsbridge_config.FB7500N100001.2017-04-28_15_50_20.txt
Timestamp: 4/28/2017 15:50:20
cluster1::*>
