system ha interconnect port show
Display the high-availability interconnect device port information
The system ha interconnect port show
command displays the high-availability interconnect device port physical layer and link layer status information.
[-fields <fieldname>,…]
If you specify the
parameter, the command displays only the fields that you specify. - |
[-instance ]
Use this parameter to display all the fields from all nodes in the cluster.
[-node {<nodename>|local}]
- Node-
Use this parameter to display all the fields from the specified node in the cluster.
[-link-monitor {on|off}]
- Link Monitor Detection-
Selects the nodes that match this parameter value.
[-port <integer>,…]
- Port Number-
[-phy-layer-state {invalid|sleep|polling|disabled|port-configuration-testing|linkup|link-error-recovery|phytest|reserved}]
- Physical Layer State-
[-link-layer-state {invalid|down|initialize|armed|active|reserved}]
- Link Layer State-
[-phy-link-up-count <integer>,…]
- Physical Link Up Count-
Selects the nodes that match this parameter value. The value is total number of times the link on a given port is transitioned up.
[-phy-link-down-count <integer>,…]
- Physical Link Down Count-
Selects the nodes that match this parameter value. The value is total number of times the link on a given port is transitioned down.
[-is-active-link {true|false}]
- Is the Link Active-
true
means the interconnect data channels are established on this link.
The following example displays the HA interconnect device port information on FAS8000 series nodes in the cluster:
cluster1::*> system ha interconnect port show Physical Link Link Layer Layer Physical Physical Active Node Monitor Port State State Link Up Link Down Link -------------- ------- ---- -------- --------- -------- --------- ------ ic-f8040-01 on 0 linkup active 1 0 true 1 linkup active 1 0 false ic-f8040-02 on 0 linkup active 1 0 true 1 linkup active 1 0 false 2 entries were displayed.
