ONTAP commands
system ha interconnect port show
Display the high-availability interconnect device port information
The system ha interconnect port show command displays the high-availability interconnect device port physical layer and link layer status information.
[-fields <fieldname>,…​]
If you specify the -fields <fieldname>,…​ parameter, the command displays only the fields that you specify.
| [-instance ] (privilege: advanced) }
Use this parameter to display all the fields from all nodes in the cluster.
[-node {<nodename>|local}] - Node (privilege: advanced)
Use this parameter to display all the fields from the specified node in the cluster.
[-link-monitor {on|off}] - Link Monitor Detection (privilege: advanced)
Selects the nodes that match this parameter value.
[-port <integer>,…​] - Port Number (privilege: advanced)
[-phy-layer-state {invalid|sleep|polling|disabled|port-configuration-testing|linkup|link-error-recovery|phytest|reserved}] - Physical Layer State (privilege: advanced)
[-link-layer-state {invalid|down|initialize|armed|active|reserved}] - Link Layer State (privilege: advanced)
[-phy-link-up-count <integer>,…​] - Physical Link Up Count (privilege: advanced)
Selects the nodes that match this parameter value. The value is total number of times the link on a given port is transitioned up.
[-phy-link-down-count <integer>,…​] - Physical Link Down Count (privilege: advanced)
Selects the nodes that match this parameter value. The value is total number of times the link on a given port is transitioned down.
[-is-active-link {true|false}] - Is the Link Active (privilege: advanced)
Selects the nodes that match this parameter value. The value true means the interconnect data channels are established on this link.
The following example displays the HA interconnect device port information on FAS8000 series nodes in the cluster:
cluster1::*> system ha interconnect port show
                               Physical  Link
                Link           Layer     Layer      Physical   Physical  Active
Node            Monitor  Port  State     State       Link Up  Link Down  Link
ic-f8040-01     on
                            0  linkup    active            1          0  true
                            1  linkup    active            1          0  false
ic-f8040-02     on
2 entries were displayed.
