system node hardware tape library show
Display information about tape libraries
This command displays the following information about tape libraries:
  • Node to which the tape library is attached
  • Device ID of the tape library
  • Description of the tape library
  • NDMP path of the tape library
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Displays detailed information about tape libraries on the specified node.
[-device-id <text>] - Device ID
Selects information about the tape library that has the specified device ID.
[-description <text>] - Description
Selects information about the tape library or libraries that have the specified description.
[-wwn <text>] - World Wide Name
Selects information about the tape library that has the specified worldwide name.
[-serial-number <text>] - Serial Number
Selects information about the tape library that has the specified serial number.
[-ndmp-path <text>] - NDMP Path
Selects information about the tape library or libraries that have the specified NDMP path.
The following example displays information about all tape libraries attached to the cluster:
cluster1::> system node hardware tape library show
Node   Device Id Drive Description    NDMP Path
cluster1-00
       0b.125L1  HP       MSL G3      mc1
                 Series
       0c.125L1  HP       MSL G3      mc0
                 Series
2 entries were displayed.
