system node hardware tape library show
Display information about tape libraries
This command displays the following information about tape libraries:
Node to which the tape library is attached
Device ID of the tape library
Description of the tape library
NDMP path of the tape library
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node {<nodename>|local}]- Node
Displays detailed information about tape libraries on the specified node.
- [-device-id <text>]- Device ID
Selects information about the tape library that has the specified device ID.
- [-description <text>]- Description
Selects information about the tape library or libraries that have the specified description.
- [-wwn <text>]- World Wide Name
Selects information about the tape library that has the specified worldwide name.
- [-serial-number <text>]- Serial Number
Selects information about the tape library that has the specified serial number.
- [-ndmp-path <text>]- NDMP Path
Selects information about the tape library or libraries that have the specified NDMP path.
The following example displays information about all tape libraries attached to the cluster:
cluster1::> system node hardware tape library show
Node   Device Id Drive Description    NDMP Path
cluster1-00
       0b.125L1  HP       MSL G3      mc1
                 Series
       0c.125L1  HP       MSL G3      mc0
                 Series
2 entries were displayed.
 PDFs
PDFs
