storage failover hwassist stats clear
- PDF of this doc site
Creating your file...
Your file is ready
Clear the hwassist statistics
The ` storage failover hwassist stats clear` command clears the statistics information maintained by Hardware Assist functionality.
-node {<nodename>|local}
- Node-
This specifies the node on which the statistics are to be cleared.
The following example clears the hwassist statistics on the node cluster1-01:
cluster1::> storage failover hwassist stats clear -node cluster1-01
