security multi-admin-verify approval-group delete
Delete an Approval Group
The security multi-admin-verify approval-group delete
command deletes the specified approval group.
-vserver <vserver>
- Vserver-
This specifies the Vserver information to which the approval group is associated with. This is an optional parameter. This parameter defaults to Cluster server and supports only Cluster servers.
-name <text>
- Group Name-
This specifies the name of an approval group to be deleted.
The following example deletes the approval group, group1:
cluster1::> security multi-admin-verify approval-group delete -name group1
