ONTAP commands
vserver services ndmp restartable-backup delete
Delete an NDMP restartable backup context
The vserver services ndmp restartable-backup delete command deletes an NDMP restartable backup context. The -force flag can be used to forcibly destroy a NDMP restartable backup context.
-vserver <Vserver Name> - Vserver
This parameter specifies the name of the Vserver for which NDMP restartable backup context is to be deleted.
-context-id <UUID> - Context Identifier
This parameter specifies the NDMP restartable backup context ID which needs to be deleted.
[-force <true>] - Force Delete (privilege: advanced)
If this parameter is specified, the context is deleted even if there are internal errors.
The following example shows how to delete an NDMP restartable backup context:
cluster1::> vserver services ndmp restartable-backup delete -vserver cluster1-01 -context-id 0f8f5c44-d540-11e5-8c45-005056963504
    cluster1::>
