system snmp community delete
Deletes community with the specified access control type
The system snmp community delete command deletes communities with the specified access control type. Only read-only communities are supported.
-vserver <Vserver Name> - Vserver
This parameter specifies the Vserver from which you wish to delete the community. If no Vserver is specified, the community is deleted from the admin Vserver.
-community-name <text> - Community
Specify the name of the community.
-type <ctype> - access type
Specify 'ro' for a read-only community.
The following example deletes the read-only community 'private':
cluster1::> system snmp community delete -type ro
      -community-name private
uster1::> system snmp community show
This table is currently empty.
