qos adaptive-policy-group show
Display a list of adaptive policy groups
The qos adaptive-policy-group show
command shows the current settings of the adaptive policy groups on a cluster. You can view the list of adaptive policy groups and also the detailed information about a specific adaptive policy group.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-policy-group <text>]
- Name-
Selects the adaptive policy groups that match this parameter value.
Adaptive policy groups define measurable service level objectives (SLOs) that adjust based on the storage object used space or the storage object allocated space.
[-vserver <vserver name>]
- Vserver-
If this parameter is specified, the command displays information only about the adaptive policy groups with a matching vserver.
[-uuid <UUID>]
- Uuid-
If this parameter is specified, the command displays information only about the adaptive policy groups with the specified UUID.
[-pgid <integer>]
- ID-
If this parameter is specified, the command displays information only about the adaptive policy groups that match the given policy group ID, which is an integer that uniquely identifies the adaptive policy group.
[-expected-iops {<integer>[IOPS[/{GB|TB}]] (default: TB)}]
- Expected IOPS-
If this parameter is specified, the command displays information only about the adaptive policy groups with the specified minimum expected IOPS per TB or GB.
[-peak-iops {<integer>[IOPS[/{GB|TB}]] (default: TB)}]
- Peak IOPS-
If this parameter is specified, the command displays information only about the adaptive policy groups with the specified maximum possible IOPS per TB or GB.
[-absolute-min-iops <qos_tput>]
- Absolute Minimum IOPS-
If this parameter is specified, the command displays information only about the adaptive policy groups with the specified absolute minimum IOPS.
[-expected-iops-allocation {used-space|allocated-space}]
- Expected IOPS Allocation-
If this parameter is specified, the command displays information only about the adaptive policy groups with the specified expected IOPS allocation policy used to compute the expected IOPS per TB or GB.
[-peak-iops-allocation {used-space|allocated-space}]
- Peak IOPS Allocation-
If this parameter is specified, the command displays information only about the adaptive policy groups with the specified peak IOPS allocation policy used to compute the maximum possible IOPS per TB or GB.
[-block-size {ANY|4K|8K|16K|32K|64K|128K}]
- Block Size-
Specifies the I/O block size for the QoS adaptive policy group. The default value is "ANY". When block-size of "ANY" is specified, then control is by IOPS. When block-size other than "ANY" is specified, then control is by IOPS and bytes per second(bps). bps is the product of IOPS and block-size.
[-num-workloads <integer>]
- Number of Workloads-
If this parameter is specified, the command displays information only about the adaptive policy groups with the specified number of workloads.
The example above displays all adaptive policy groups on the cluster.
cluster1::> qos adaptive-policy-group show qos adaptive-policy-group show Expected Peak Minimum Block Name Vserver Wklds IOPS IOPS IOPS Size ------------ ------- ------ ----------- ------------ -------- ----- apg1 vs1 1 100IOPS/MB 1000IOPS/MB 75IOPS 8K apg2 vs1 1 100IOPS/MB 1000IOPS/MB 75IOPS 4K extreme clus-1 0 6144IOPS/TB 12288IOPS/TB 1000IOPS ANY performance clus-1 0 2048IOPS/TB 4096IOPS/TB 500IOPS ANY value clus-1 0 128IOPS/TB 512IOPS/TB 75IOPS ANY 5 entries were displayed.
