ONTAP commands
qos adaptive-policy-group show
Display a list of adaptive policy groups
The qos adaptive-policy-group show command shows the current settings of the adaptive policy groups on a cluster. You can view the list of adaptive policy groups and also the detailed information about a specific adaptive policy group.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-policy-group <text>] - Name
Selects the adaptive policy groups that match this parameter value.
Adaptive policy groups define measurable service level objectives (SLOs) that adjust based on the storage object used space or the storage object allocated space.
[-vserver <vserver name>] - Vserver
If this parameter is specified, the command displays information only about the adaptive policy groups with a matching vserver.
[-uuid <UUID>] - Uuid
If this parameter is specified, the command displays information only about the adaptive policy groups with the specified UUID.
[-pgid <integer>] - ID
If this parameter is specified, the command displays information only about the adaptive policy groups that match the given policy group ID, which is an integer that uniquely identifies the adaptive policy group.
[-expected-iops {<integer>[IOPS[/{GB|TB}]] (default: TB)}] - Expected IOPS
If this parameter is specified, the command displays information only about the adaptive policy groups with the specified minimum expected IOPS per TB or GB.
[-peak-iops {<integer>[IOPS[/{GB|TB}]] (default: TB)}] - Peak IOPS
If this parameter is specified, the command displays information only about the adaptive policy groups with the specified maximum possible IOPS per TB or GB.
[-absolute-min-iops <qos_tput>] - Absolute Minimum IOPS
If this parameter is specified, the command displays information only about the adaptive policy groups with the specified absolute minimum IOPS.
[-expected-iops-allocation {used-space|allocated-space}] - Expected IOPS Allocation
If this parameter is specified, the command displays information only about the adaptive policy groups with the specified expected IOPS allocation policy used to compute the expected IOPS per TB or GB.
[-peak-iops-allocation {used-space|allocated-space}] - Peak IOPS Allocation
If this parameter is specified, the command displays information only about the adaptive policy groups with the specified peak IOPS allocation policy used to compute the maximum possible IOPS per TB or GB.
[-block-size {ANY|4K|8K|16K|32K|64K|128K}] - Block Size
Specifies the I/O block size for the QoS adaptive policy group. The default value is "ANY". When block-size of "ANY" is specified, then control is by IOPS. When block-size other than "ANY" is specified, then control is by IOPS and bytes per second(bps). bps is the product of IOPS and block-size.
[-num-workloads <integer>] - Number of Workloads
If this parameter is specified, the command displays information only about the adaptive policy groups with the specified number of workloads.
The example above displays all adaptive policy groups on the cluster.
cluster1::> qos adaptive-policy-group show
Expected    Peak         Minimum  Block
Name         Vserver Wklds  IOPS        IOPS         IOPS     Size
apg1         vs1     1      100IOPS/MB  1000IOPS/MB  75IOPS   8K
apg2         vs1     1      100IOPS/MB  1000IOPS/MB  75IOPS   4K
extreme      clus-1  0      6144IOPS/TB 12288IOPS/TB 1000IOPS ANY
performance  clus-1  0      2048IOPS/TB 4096IOPS/TB  500IOPS  ANY
value        clus-1  0      128IOPS/TB  512IOPS/TB   75IOPS   ANY
5 entries were displayed.
