vserver remove-aggregates
Remove aggregates from the Vserver
The vserver remove-aggregates command removes aggregates from the Vserver.
-vserver <vserver> - Vserver
Specifies the Vserver from which aggregates have to be removed.
-aggregates <aggregate name>,…​ - List of Aggregates to Be Removed
Specifies the list of aggregates to remove from the Vserver.
The following example illustrates how to remove aggregates aggr1 and aggr2 from a Vserver named vs.example.com :
cluster1::> vserver remove-aggregates -vserver vs.example.com -aggregates aggr1,aggr2
