system node power on
Power nodes on
This command switches on the power of the main controller of the specified node. This command works for a single node only and the full name of the node must be entered exactly.
-node {<nodename>|local}
- Node-
This parameter specifies the node whose power you want to switch on.
The following example switches on the power of node2.
cluster1::> set advanced Warning: These advanced commands are potentially dangerous; use them only when directed to do so by NetApp personnel. Do you want to continue? {y|n}: y cluster1::*> cluster1::*> system node power on -node node2 cluster1::*>
