metrocluster configuration-settings interface show
Display the network logical interfaces provisioned for MetroCluster
The metrocluster configuration-settings interface show
command displays the network logical interfaces that were provisioned for MetroCluster.
[-fields <fieldname>,…]
If you specify the
parameter, the command displays only the fields that you specify. - |
[-instance ]
If this parameter is specified, the command displays detailed information about all entries.
[-dr-group-id <integer>]
- DR Group ID-
If this parameter is specified, the command displays information for the matching DR group.
[-cluster-uuid <UUID>]
- Cluster UUID-
If this parameter is specified, the command displays information for the matching cluster specified by uuid.
[-cluster <Cluster name>]
- Cluster Name-
If this parameter is specified, the command displays information for the matching cluster..
[-node-uuid <UUID>]
- Node UUID-
If this parameter is specified, the command displays information for the matching nodes uuid.
[-node <text>]
- Node Name-
If this parameter is specified, the command displays information for the matching nodes.
[-home-port {<netport>|<ifgrp>}]
- Home Port-
If this parameter is specified, all interfaces with home-port set to this value are displayed.
[-address <IP Address>]
- Network Address-
If this parameter is specified, the command displays information for the matching network address.
[-netmask <Contiguous IP Mask>]
- Netmask-
If this parameter is specified, all interfaces with netmask set to this value are displayed.
[-gateway <IP Address>]
- Gateway-
If this parameter is specified, all interfaces with gateway set to this value are displayed.
[-config-state <text>]
- Configuration State-
If this parameter is specified, all interfaces with this field set to the specified value are displayed.
[-config-error-info <text>]
- Configuration Error Information-
[-vlan-id <integer>]
- Virtual LAN ID-
If this parameter is specified, all interfaces with vlan-id set to this value are displayed.
The following example illustrates display of logical interfaces configured in a four-node MetroCluster setup:
clusA::> metrocluster configuration-settings interface show DR Config Group Cluster Node Network Address Netmask Gateway State ----- ------- ------- --------------- --------------- --------------- --------- 1 clusA A1 Home Port: e0f 10.140.113.214 255.255.192.0 - completed Home Port: e0g 10.140.113.215 255.255.192.0 - completed A2 Home Port: e0f 10.140.113.216 255.255.192.0 - completed Home Port: e0g 10.140.113.217 255.255.192.0 - completed clusB B2 Home Port: e0f 10.140.113.249 255.255.192.0 - completed Home Port: e0g 10.140.113.25 255.255.192.0 - completed B1 Home Port: e0f 10.140.113.218 255.255.192.0 - completed Home Port: e0g 10.140.113.248 255.255.192.0 - completed 8 entries were displayed.
