metrocluster configuration-settings interface show
Display the network logical interfaces provisioned for MetroCluster
The metrocluster configuration-settings interface show command displays the network logical interfaces that were provisioned for MetroCluster.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>,…parameter, the command displays only the fields that you specify.
- | [-instance ]}
If this parameter is specified, the command displays detailed information about all entries.
- [-dr-group-id <integer>]- DR Group ID
If this parameter is specified, the command displays information for the matching DR group.
- [-cluster-uuid <UUID>]- Cluster UUID
If this parameter is specified, the command displays information for the matching cluster specified by uuid.
- [-cluster <Cluster name>]- Cluster Name
If this parameter is specified, the command displays information for the matching cluster..
- [-node-uuid <UUID>]- Node UUID
If this parameter is specified, the command displays information for the matching nodes uuid.
- [-node <text>]- Node Name
If this parameter is specified, the command displays information for the matching nodes.
- [-home-port {<netport>|<ifgrp>}]- Home Port
If this parameter is specified, all interfaces with home-port set to this value are displayed.
- [-address <IP Address>]- Network Address
If this parameter is specified, the command displays information for the matching network address.
- [-netmask <Contiguous IP Mask>]- Netmask
If this parameter is specified, all interfaces with netmask set to this value are displayed.
- [-gateway <IP Address>]- Gateway
If this parameter is specified, all interfaces with gateway set to this value are displayed.
- [-config-state <text>]- Configuration State
If this parameter is specified, all interfaces with this field set to the specified value are displayed.
- [-config-error-info <text>]- Configuration Error Information
- [-vlan-id <integer>]- Virtual LAN ID
If this parameter is specified, all interfaces with vlan-id set to this value are displayed.
The following example illustrates display of logical interfaces configured in a four-node MetroCluster setup:
clusA::> metrocluster configuration-settings interface show
DR        Config
Group Cluster Node    Network Address Netmask         Gateway         State
1     clusA A1
                 Home Port: e0f
                      10.140.113.214  255.255.192.0   -               completed
                 Home Port: e0g
                      10.140.113.215  255.255.192.0   -               completed
                       A2
                 Home Port: e0f
                      10.140.113.216  255.255.192.0   -               completed
                 Home Port: e0g
                      10.140.113.217  255.255.192.0   -               completed
      clusB B2
                 Home Port: e0f
                      10.140.113.249  255.255.192.0   -               completed
                 Home Port: e0g
                      10.140.113.25   255.255.192.0   -               completed
                       B1
                 Home Port: e0f
                      10.140.113.218  255.255.192.0   -               completed
                 Home Port: e0g
                      10.140.113.248  255.255.192.0   -               completed
8 entries were displayed.
 PDFs
PDFs
