system bridge modify
Modify a bridge’s configuration information
The system bridge modify enables you to modify certain parameters for identifying and accessing the FC-to-SAS bridges added for monitoring in a MetroCluster configuration.
-name <text> - Bridge Name
This parameter specifies the name of the bridge.
[-address <IP Address>] - Bridge IP Address
This parameter specifies the IP address of the bridge.
[-snmp-community <text>] - SNMP Community Set on the Bridge
This parameter specifies the SNMP community set on the bridge.
[-managed-by {SNMP|in-band}] - Bridge Management Method
This parameter specifies whether the bridge uses the SNMP or in-band management method. FibreBridge 6500N uses SNMP only; FibreBridge 7500N may use either.
[-node-visible-list <text>,…​] - Nodes Bridge is Visble To
This parameter specifies bridges that are visible to the node.
The following command modifies 'ATTO_10.226.197.16' bridge SNMP community to 'public':
cluster1::> system bridge modify -name ATTO_10.226.197.16 -address 10.226.197.16 -snmp-community public
cluster1::>
