system bridge modify
Modify a bridge's configuration information
The system bridge modify enables you to modify certain parameters for identifying and accessing the FC-to-SAS bridges added for monitoring in a MetroCluster configuration.
- -name <text>- Bridge Name
This parameter specifies the name of the bridge.
- [-node-visible-list <text>,…]- Nodes Bridge is Visble To
This parameter specifies nodes that are visible to the bridge.
The following command modifies 'ATTO_2000001086b0' bridge node-visible-list to 'nodeA,nodeB'
cluster1::> system bridge modify -name ATTO_2000001086b0 -node-visible-list nodeA,nodeB cluster1::>
 PDFs
PDFs
