ONTAP commands
vserver peer modify-local-name
Modify the local name for a peer Vserver
The vserver peer modify-local-name command modifies the local name for a remote peer Vserver. The new local name must be unique.
-peer-cluster <text> - Peer Cluster
Use this parameter to specify the peer cluster.
-peer-vserver <text> - Remote Peer Vserver
Use this parameter to specify the existing remote peer Vserver name.
-new-name <vserver> - Remote Peer Vserver Local Name
Use this parameter to specify the new local name of the peer Vserver. The new local name must conform to the same rules as a Vserver name.
cluster2::> vserver peer modify-local-name -peer-cluster cluster1 -peer-vserver vs51.example.com -new-name vs51_cluster1.example.com
