The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver peer modify-local-name
PDF of this doc site
Creating your file...
Your file is ready
Modify the local name for a peer Vserver
The vserver peer modify-local-name
command modifies the local name for a remote peer Vserver. The new local name must be unique.
-peer-cluster <text>
- Peer Cluster-
Use this parameter to specify the peer cluster.
-peer-vserver <text>
- Remote Peer Vserver-
Use this parameter to specify the existing remote peer Vserver name.
-new-name <vserver>
- Remote Peer Vserver Local Name-
Use this parameter to specify the new local name of the peer Vserver. The new local name must conform to the same rules as a Vserver name.
cluster2::> vserver peer modify-local-name -peer-cluster cluster1 -peer-vserver vs51.example.com -new-name vs51_cluster1.example.com
