security key-manager key migrate
Migrate keys from the admin Vserver’s the Onboard Key Manager to a data Vserver’s external key manager and vice versa
This command provides a mechanism to migrate the existing keys of a data Vserver from the admin Vserver’s key manager to their own key manager or vice versa. The keys stay the same and the data is not rekeyed, only the keys are migrated from one Vserver’s key manager to another. After a successful migration to the new key manager, the data Vserver keys are deleted from the previous key manager.
-from-vserver <vserver name>
- Vserver Name-
Use this parameter to specify the name of the Vserver whose key manager the keys are migrated from.
-to-vserver <vserver name>
- Vserver Name-
Use this parameter to specify the name of the Vserver whose key manager the keys are migrated to.
The following example migrates the keys of "datavs" data Vserver from "cluster-1" admin Vserver’s key manager to "datavs" data Vserver’s key manager:
cluster-1::> security key-manager key migrate -from-vserver cluster-1 -to-vserver datavs
The following example migrates the keys of "datavs" data Vserver from "datavs" data Vserver’s key manager to "cluster-1" admin Vserver’s key manager:
cluster-1::> security key-manager key migrate -from-vserver datavs -to-vserver cluster-1
