metrocluster interconnect adapter show
Display MetroCluster interconnect adapter information
The metrocluster interconnect adapter show
command displays interconnect adapter information for the nodes in a MetroCluster configuration.
This command displays the following details about the local node and the HA partner node:
Node: This field specifies the name of the node in the cluster.
Adapter Name: This field specifies the name of the interconnect adapter.
Adapter Type: This field specifies the type of the interconnect adapter.
Link Status: This field specifies the physical link status of the interconnect adapter.
Is OOD Enabled: This field specifies the out-of-order delivery status of the interconnect adapter.
IP Address: This field specifies the IP address assigned to the interconnect adapter.
Port Number: This field specifies the port number of the interconnect adapter.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-connectivity ]
Displays the connectivity information from all the interconnect adapters to the connected nodes.
[-switch ]
Displays details of switches connected to all the interconnect adapters.
[-connectivity-hidden ]
Displays additional connectivity information (IP address, Area ID, Port ID) from all the interconnect adapters to the connected nodes.
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node Name-
Displays information only about the interconnect adapters that are hosted by the specified node.
[-adapter <text>]
- Adapter-
Displays information only about the interconnect adapters that match the specified name.
[-port-name <text>]
- Port Name-
Displays information only about the interconnect adapters that host the specified port name.
[-type <text>]
- Adapter Type-
Displays information only about the interconnect adapters that match the specified adapter type.
[-physical-status <text>]
- Physical Status-
Displays information only about the interconnect adapters that match the specified physical status.
[-wwn <text>]
- Adapter Port World Wide Name-
Displays information only about the interconnect adapters that match the specified world wide name.
[-address <text>]
- IP Address-
Displays information only about the interconnect adapters that match the specified IP address.
[-firmware-version <text>]
- Firmware Version-
Displays information only about the interconnect adapters that match the specified firmware version.
[-link-speed <text>]
- Link Speed-
Displays information only about the interconnect adapters that match the specified link speed.
[-link-speed-neg-type <text>]
- Link Speed Negotiation Type-
Displays information only about the interconnect adapters that match the specified negotiated link speed type.
[-switch-name <text>]
- Switch Name-
Displays information only about the interconnect adapters that are connected to the specified switch.
[-switch-model <text>]
- Switch Model-
Displays information only about the interconnect adapters that are connected to the switch with the specified model.
[-switch-wwn <text>]
- Switch WWName-
Displays information only about the interconnect adapters that are connected to the switch with the specified world wide name.
[-switch-vendor <text>]
- Switch Vendor-
Displays information only about the interconnect adapters that are connected to the switch with the specified vendor.
[-switch-status <text>]
- Switch Status-
Displays information only about the interconnect adapters that are connected to the switch with the specified operational status.
[-switch-port-number <text>]
- Switch Port Number-
Displays information only about the interconnect adapters that are connected to the switch with the specified port number.
[-switch-port-wwpn <text>]
- Switch Port WWPN-
Displays information only about the interconnect adapters that are connected to the switch with the specified word wide port name.
[-remote-adapter-name-list <text>,…]
- Remote Adapter Name List-
Displays information only about the interconnect adapters that are connected to the specified remote adapters.
[-remote-adapter-wwn-list <text>,…]
- Remote Adapter WWName List-
Displays information only about the interconnect adapters that are connected to the remote adapters with the specified world wide names.
[-remote-adapter-address-list <text>,…]
- Remote Adapter IP Address List-
Displays information only about the interconnect adapters that are connected to the remote adapters with the specified IP addresses.
[-remote-adapter-port-id-list <Hex Integer>,…]
- Remote Adapter Port ID List-
Displays information only about the interconnect adapters that are connected to the remote adapters with the specified port IDs.
[-remote-adapter-domain-id-list <integer>,…]
- Remote Adapter Domain ID List-
Displays information only about the interconnect adapters that are connected to the remote adapters with the specified domain IDs.
[-remote-adapter-area-id-list <integer>,…]
- Remote Adapter Area ID List-
Displays information only about the interconnect adapters that are connected to the remote adapters with the specified Area IDs.
[-remote-partner-system-id-list <integer>,…]
- Remote Partner System ID List-
Displays information only about the interconnect adapters that are connected to the remote nodes with the specified System IDs.
[-remote-partner-name-list {<nodename>|local}]
- Remote Partner Name List-
Displays information only about the interconnect adapters that are connected to the specified remote nodes.
[-is-ood-enabled {true|false}]
- Is Out-of-Order Delivery Enabled?-
Displays information only about the interconnect adapters that match the specified out-of-order delivery setting.
The following example shows the output of the command during normal operation (neither cluster is in switchover state):
clusA::> metrocluster interconnect adapter show Link Is OOD Node Adapter Type Status Enabled? IP Address Port Number ------------ --------------- ----- ------ -------- ----------- ----------- clusA-01 cxgb3_0 iWARP Up false 10.0.1.1 c0a clusA-01 cxgb3_0 iWARP Down false 10.0.2.1 c0b clusA-01 fcvi_device_0 FC-VI Up false 1.0.0.1 1a clusA-01 fcvi_device_1 FC-VI Up false 2.0.0.3 1b clusA-02 cxgb3_0 iWARP Up false 10.0.1.2 c0a clusA-02 cxgb3_0 iWARP Down false 10.0.2.2 c0b clusA-02 fcvi_device_0 FC-VI Up false 1.0.1.1 1a clusA-02 fcvi_device_1 FC-VI Up false 2.0.1.3 1b
The following example shows the output of the command after MetroCluster switchover is performed:
clusA::> metrocluster interconnect adapter show Link Is OOD Node Adapter Type Status Enabled? IP Address Port Number ------------ --------------- ----- ------ -------- ----------- ----------- clusA-01 cxgb3_0 iWARP Up false 10.0.1.1 c0a clusA-01 cxgb3_0 iWARP Down false 10.0.2.1 c0b clusA-01 fcvi_device_0 FC-VI Down false 1.0.0.1 1a clusA-01 fcvi_device_1 FC-VI Down false 2.0.0.3 1b clusA-02 cxgb3_0 iWARP Up false 10.0.1.2 c0a clusA-02 cxgb3_0 iWARP Down false 10.0.2.2 c0b clusA-02 fcvi_device_0 FC-VI Down false 1.0.1.1 1a clusA-02 fcvi_device_1 FC-VI Down false 2.0.1.3 1b
The following example shows the output of the command with connectivity field during normal operation (neither cluster is in swithover state):
clusA::> metrocluster interconnect adapter show -connectivity -node local -type FC-VI Adapter Name: fcvi_device_0 WWName: 21:00:00:24:ff:32:01:68 PortNo: 1a Remote Adapters: Adapter Name Partner Node Name World Wide Name PortId ------------ ----------------- ----------------------- ------ fcvi_device_0 clusA-01 21:00:00:24:ff:32:01:80 65536 fcvi_device_0 clusB-01 21:00:00:24:ff:32:01:54 131072 fcvi_device_0 clusB-02 21:00:00:24:ff:32:01:60 131328 Adapter Name: fcvi_device_1 WWName: 21:00:00:24:ff:32:01:69 PortNo: 1b Remote Adapters: Adapter Name Partner Node Name World Wide Name PortId ------------ ----------------- ----------------------- ------ fcvi_device_1 clusA-01 21:00:00:24:ff:32:01:81 196608 fcvi_device_1 clusB-01 21:00:00:24:ff:32:01:55 262144 fcvi_device_1 clusB-02 21:00:00:24:ff:32:01:61 262400
The following example shows the output of the command with connectivity field after MetroCluster swithover is performed.
clusA::> metrocluster interconnect adapter show -connectivity -node local -type FC-VI Adapter Name: fcvi_device_0 WWName: 21:00:00:24:ff:32:01:68 PortNo: 1a Remote Adapters: Adapter Name Partner Node Name World Wide Name PortId ------------ ----------------- ----------------------- ------ fcvi_device_0 clusA-01 21:00:00:24:ff:32:01:80 65536 Adapter Name: fcvi_device_1 WWName: 21:00:00:24:ff:32:01:69 PortNo: 1b Remote Adapters: Adapter Name Partner Node Name World Wide Name PortId ------------ ----------------- ----------------------- ------ fcvi_device_1 clusA-01 21:00:00:24:ff:32:01:81 196608
