- ONTAP 9.11.1 commands
- exit
- history
- man
- redo
- rows
- set
- top
- up
application commands
autobalance commands
cluster commands
- cluster add-node-status-clear-failed
- cluster add-node
- cluster create
- cluster join
- cluster modify
- cluster ping-cluster
- cluster remove-node
- cluster setup
- cluster show
cluster agent commands
cluster contact-info commands
cluster controller-replacement commands
- cluster controller-replacement network displaced-interface delete
- cluster controller-replacement network displaced-interface restore-home-node
- cluster controller-replacement network displaced-interface show
- cluster controller-replacement network displaced-vlans delete
- cluster controller-replacement network displaced-vlans restore
- cluster controller-replacement network displaced-vlans show
cluster date commands
cluster ha commands
cluster identity commands
cluster image commands
- cluster image cancel-update
- cluster image pause-update
- cluster image resume-update
- cluster image show-update-history
- cluster image show-update-log-detail
- cluster image show-update-progress
- cluster image update
- cluster image validate
- cluster image package delete
- cluster image package get
- cluster image package show-repository
cluster kernel-service commands
cluster log-forwarding commands
cluster peer commands
- cluster peer create
- cluster peer delete
- cluster peer modify-local-name
- cluster peer ping
- cluster peer show
- cluster peer connection show
- cluster peer health show
- cluster peer offer cancel
- cluster peer offer modify
- cluster peer offer show
- cluster peer policy modify
- cluster peer policy show
cluster quorum-service commands
cluster ring commands
cluster statistics commands
cluster time-service commands
- cluster time-service ntp key create
- cluster time-service ntp key delete
- cluster time-service ntp key modify
- cluster time-service ntp key show
- cluster time-service ntp security modify
- cluster time-service ntp security show
- cluster time-service ntp server create
- cluster time-service ntp server delete
- cluster time-service ntp server modify
- cluster time-service ntp server reset
- cluster time-service ntp server show
- cluster time-service ntp status show
event commands
job commands
lun commands
- lun convert-from-namespace
- lun create
- lun delete
- lun maxsize
- lun modify
- lun move-in-volume
- lun resize
- lun show
lun bind commands
lun copy commands
lun igroup commands
lun import commands
lun mapping commands
lun move commands
lun persistent-reservation commands
lun portset commands
lun transition commands
metrocluster commands
- metrocluster configure
- metrocluster heal
- metrocluster modify
- metrocluster remove-dr-group
- metrocluster show
- metrocluster switchback
- metrocluster switchover
metrocluster check commands
- metrocluster check disable-periodic-check
- metrocluster check enable-periodic-check
- metrocluster check run
- metrocluster check show
- metrocluster check aggregate show
- metrocluster check cluster show
- metrocluster check config-replication show-aggregate-eligibility
- metrocluster check config-replication show-capture-status
- metrocluster check connection show
- metrocluster check lif repair-placement
- metrocluster check lif show
- metrocluster check node show
- metrocluster check volume show
metrocluster config-replication commands
metrocluster configuration-settings commands
- metrocluster configuration-settings show-status
- metrocluster configuration-settings calibration measure
- metrocluster configuration-settings calibration show
- metrocluster configuration-settings connection check
- metrocluster configuration-settings connection connect
- metrocluster configuration-settings connection disconnect
- metrocluster configuration-settings connection show
- metrocluster configuration-settings dr-group create
- metrocluster configuration-settings dr-group delete
- metrocluster configuration-settings dr-group show
- metrocluster configuration-settings interface create
- metrocluster configuration-settings interface delete
- metrocluster configuration-settings interface show
- metrocluster configuration-settings mediator add
- metrocluster configuration-settings mediator remove
- metrocluster configuration-settings mediator show
metrocluster interconnect commands
metrocluster node commands
metrocluster operation commands
metrocluster transition commands
metrocluster vserver commands
network commands
- network ping
- network ping6
- network test-path
- network traceroute
- network traceroute6
network arp commands
network bgp commands
- network bgp config create
- network bgp config delete
- network bgp config modify
- network bgp config show
- network bgp defaults modify
- network bgp defaults show
- network bgp peer-group create
- network bgp peer-group delete
- network bgp peer-group modify
- network bgp peer-group rename
- network bgp peer-group show
- network bgp vserver-status show
network cloud commands
network connections commands
network device-discovery commands
network fcp commands
network interface commands
- network interface create
- network interface delete
- network interface migrate-all
- network interface modify
- network interface rename
- network interface revert
- network interface show
- network interface start-cluster-check
- network interface capacity show
- network interface capacity details show
- network interface check cluster-connectivity show
- network interface check cluster-connectivity start
- network interface check failover show
- network interface dns-lb-stats show
- network interface failover-groups add-targets
- network interface failover-groups create
- network interface failover-groups delete
- network interface failover-groups modify
- network interface failover-groups remove-targets
- network interface failover-groups rename
- network interface failover-groups show
- network interface lif-weights show
- network interface service show
- network interface service-policy add-service
- network interface service-policy clone
- network interface service-policy create
- network interface service-policy delete
- network interface service-policy modify-service
- network interface service-policy remove-service
- network interface service-policy rename
- network interface service-policy restore-defaults
- network interface service-policy show
network ipspace commands
network ndp commands
network options commands
- network options cluster-health-notifications modify
- network options cluster-health-notifications show
- network options detect-switchless-cluster modify
- network options detect-switchless-cluster show
- network options ipv6 modify
- network options ipv6 show
- network options load-balancing modify
- network options load-balancing show
- network options multipath-routing modify
- network options multipath-routing show
- network options port-health-monitor disable-monitors
- network options port-health-monitor enable-monitors
- network options port-health-monitor modify
- network options port-health-monitor show
- network options send-soa modify
- network options send-soa show
- network options switchless-cluster modify
- network options switchless-cluster show
network port commands
- network port delete
- network port modify
- network port show-address-filter-info
- network port show
- network port broadcast-domain add-ports
- network port broadcast-domain create
- network port broadcast-domain delete
- network port broadcast-domain merge
- network port broadcast-domain modify
- network port broadcast-domain move
- network port broadcast-domain remove-ports
- network port broadcast-domain rename
- network port broadcast-domain show
- network port broadcast-domain split
- network port ifgrp add-port
- network port ifgrp create
- network port ifgrp delete
- network port ifgrp remove-port
- network port ifgrp show
- network port reachability repair
- network port reachability scan
- network port reachability show
- network port vip create
- network port vip delete
- network port vip show
- network port vlan create
- network port vlan delete
- network port vlan show
network qos-marking commands
network route commands
network subnet commands
network test-link commands
network tuning commands
protection-type commands
qos commands
qos adaptive-policy-group commands
qos policy-group commands
qos settings commands
qos statistics commands
- qos statistics characteristics show
- qos statistics latency show
- qos statistics performance show
- qos statistics resource cpu show
- qos statistics resource disk show
- qos statistics volume characteristics show
- qos statistics volume latency show
- qos statistics volume performance show
- qos statistics volume resource cpu show
- qos statistics volume resource disk show
- qos statistics workload characteristics show
- qos statistics workload latency show
- qos statistics workload performance show
- qos statistics workload resource cpu show
- qos statistics workload resource disk show
qos workload commands
san commands
security commands
- security snmpusers
security anti-ransomware commands
- security anti-ransomware volume disable
- security anti-ransomware volume dry-run
- security anti-ransomware volume enable
- security anti-ransomware volume pause
- security anti-ransomware volume resume
- security anti-ransomware volume show
- security anti-ransomware volume attack clear-suspect
- security anti-ransomware volume attack generate-report
- security anti-ransomware volume attack-detection-parameters modify
- security anti-ransomware volume attack-detection-parameters show
- security anti-ransomware volume space show
- security anti-ransomware volume workload-behavior show
- security anti-ransomware volume workload-behavior update-baseline-from-surge
security audit commands
security certificate commands
- security certificate create
- security certificate delete
- security certificate generate-csr
- security certificate install
- security certificate print
- security certificate rename
- security certificate show-generated
- security certificate show-truststore
- security certificate show-user-installed
- security certificate sign
- security certificate ca-issued revoke
- security certificate ca-issued show
- security certificate config modify
- security certificate config show
- security certificate truststore check
- security certificate truststore clear
- security certificate truststore load
security config commands
security cryptomod-fips commands
security ipsec commands
- security ipsec show-ikesa
- security ipsec show-ipsecsa
- security ipsec ca-certificate add
- security ipsec ca-certificate remove
- security ipsec ca-certificate show
- security ipsec config modify
- security ipsec config show
- security ipsec policy create
- security ipsec policy delete
- security ipsec policy modify
- security ipsec policy show
security key-manager commands
- security key-manager add
- security key-manager create-key
- security key-manager delete-key-database
- security key-manager delete-kmip-config
- security key-manager prepare-to-downgrade
- security key-manager query
- security key-manager restore
- security key-manager setup
- security key-manager show-key-store
- security key-manager update-passphrase
- security key-manager backup show
- security key-manager config modify
- security key-manager config show
- security key-manager external add-servers
- security key-manager external disable
- security key-manager external enable
- security key-manager external modify-server
- security key-manager external remove-servers
- security key-manager external restore
- security key-manager external show-status
- security key-manager external azure check
- security key-manager external azure disable
- security key-manager external azure enable
- security key-manager external azure rekey-external
- security key-manager external azure rekey-internal
- security key-manager external azure restore
- security key-manager external azure show
- security key-manager external azure update-client-secret
- security key-manager external azure update-credentials
- security key-manager external gcp check
- security key-manager external gcp disable
- security key-manager external gcp enable
- security key-manager external gcp rekey-external
- security key-manager external gcp rekey-internal
- security key-manager external gcp restore
- security key-manager external gcp show
- security key-manager external gcp update-credentials
- security key-manager key create
- security key-manager key delete
- security key-manager key migrate
- security key-manager key query
- security key-manager key show
- security key-manager key key-table create
- security key-manager key key-table delete
- security key-manager key key-table modify
- security key-manager key key-table show
- security key-manager onboard disable
- security key-manager onboard enable
- security key-manager onboard show-backup
- security key-manager onboard sync
- security key-manager onboard update-passphrase
- security key-manager onboard verify-backup
- security key-manager policy show
security login commands
- security login create
- security login delete
- security login expire-password
- security login lock
- security login modify
- security login password-prepare-to-downgrade
- security login show
- security login unlock
- security login whoami
- security login banner modify
- security login banner show
- security login domain-tunnel create
- security login domain-tunnel delete
- security login domain-tunnel modify
- security login domain-tunnel show
- security login motd modify
- security login motd show
- security login publickey create
- security login publickey delete
- security login publickey load-from-uri
- security login publickey modify
- security login publickey show
- security login rest-role create
- security login rest-role delete
- security login rest-role modify
- security login rest-role show
- security login rest-role expanded-rest-roles modify
- security login rest-role expanded-rest-roles show
- security login role create
- security login role delete
- security login role modify
- security login role prepare-to-downgrade
- security login role show-ontapi
- security login role config modify
- security login role config reset
- security login role config show
security multi-admin-verify commands
- security multi-admin-verify modify
- security multi-admin-verify show
- security multi-admin-verify approval-group create
- security multi-admin-verify approval-group delete
- security multi-admin-verify approval-group modify
- security multi-admin-verify approval-group replace
- security multi-admin-verify approval-group show
- security multi-admin-verify request approve
- security multi-admin-verify request create
- security multi-admin-verify request delete
- security multi-admin-verify request show-pending
- security multi-admin-verify request veto
- security multi-admin-verify rule create
- security multi-admin-verify rule delete
- security multi-admin-verify rule modify
- security multi-admin-verify rule show
security protocol commands
security saml-sp commands
security session commands
- security session kill-cli
- security session show
- security session limit create
- security session limit delete
- security session limit modify
- security session limit show
- security session limit application create
- security session limit application delete
- security session limit application modify
- security session limit application show
- security session limit location create
- security session limit location delete
- security session limit location modify
- security session limit location show
- security session limit request create
- security session limit request delete
- security session limit request modify
- security session limit request show
- security session limit user create
- security session limit user delete
- security session limit user modify
- security session limit user show
- security session limit vserver create
- security session limit vserver delete
- security session limit vserver modify
- security session limit vserver show
- security session request-statistics show-by-application
- security session request-statistics show-by-location
- security session request-statistics show-by-request
- security session request-statistics show-by-user
- security session request-statistics show-by-vserver
security ssh commands
security ssl commands
security tpm commands
snaplock commands
snapmirror commands
- snapmirror abort
- snapmirror break
- snapmirror create
- snapmirror delete
- snapmirror initialize-ls-set
- snapmirror list-destinations
- snapmirror modify
- snapmirror promote
- snapmirror protect
- snapmirror quiesce
- snapmirror release
- snapmirror restore
- snapmirror resume
- snapmirror resync
- snapmirror set-options
- snapmirror show-history
- snapmirror show
- snapmirror update-ls-set
- snapmirror update
snapmirror config-replication commands
snapmirror failover commands
snapmirror mediator commands
snapmirror object-store commands
snapmirror policy commands
snapmirror snapshot-owner commands
statistics commands
- statistics show-periodic
- statistics show
- statistics start
- statistics stop
statistics aggregate commands
statistics cache commands
statistics catalog commands
statistics disk commands
statistics lif commands
statistics lun commands
statistics namespace commands
statistics nfs commands
statistics node commands
statistics oncrpc commands
statistics port commands
statistics preset commands
statistics qtree commands
statistics samples commands
statistics settings commands
statistics system commands
statistics top commands
statistics volume commands
statistics vserver commands
statistics workload commands
statistics-v1 commands
storage-service commands
storage commands
storage aggregate commands
- storage aggregate add-disks
- storage aggregate auto-provision
- storage aggregate create
- storage aggregate delete
- storage aggregate mirror
- storage aggregate modify
- storage aggregate offline
- storage aggregate online
- storage aggregate remove-stale-record
- storage aggregate rename
- storage aggregate restrict
- storage aggregate scrub
- storage aggregate show-auto-provision-progress
- storage aggregate show-cumulated-efficiency
- storage aggregate show-efficiency
- storage aggregate show-resync-status
- storage aggregate show-scrub-status
- storage aggregate show-space
- storage aggregate show-spare-disks
- storage aggregate show-status
- storage aggregate verify
- storage aggregate efficiency show
- storage aggregate efficiency stat
- storage aggregate efficiency cross-volume-dedupe revert-to
- storage aggregate efficiency cross-volume-dedupe show
- storage aggregate efficiency cross-volume-dedupe start
- storage aggregate efficiency cross-volume-dedupe stop
- storage aggregate encryption show-key-id
- storage aggregate inode-upgrade resume
- storage aggregate inode-upgrade show
- storage aggregate object-store attach
- storage aggregate object-store mirror
- storage aggregate object-store modify
- storage aggregate object-store show-freeing-status
- storage aggregate object-store show-resync-status
- storage aggregate object-store show-space
- storage aggregate object-store unmirror
- storage aggregate object-store config create
- storage aggregate object-store config delete
- storage aggregate object-store config modify
- storage aggregate object-store config rename
- storage aggregate object-store config show
- storage aggregate object-store profiler abort
- storage aggregate object-store profiler show
- storage aggregate object-store profiler start
- storage aggregate object-store put-rate-limit modify
- storage aggregate object-store put-rate-limit show
- storage aggregate plex delete
- storage aggregate plex offline
- storage aggregate plex online
- storage aggregate plex show
- storage aggregate reallocation quiesce
- storage aggregate reallocation restart
- storage aggregate reallocation schedule
- storage aggregate reallocation show
- storage aggregate reallocation start
- storage aggregate reallocation stop
- storage aggregate relocation show
- storage aggregate relocation start
- storage aggregate resynchronization modify
- storage aggregate resynchronization show
- storage aggregate resynchronization options modify
- storage aggregate resynchronization options show
storage array commands
storage automated-working-set-analyzer commands
storage disk commands
- storage disk assign
- storage disk fail
- storage disk reassign
- storage disk refresh-ownership
- storage disk remove-reservation
- storage disk removeowner
- storage disk replace
- storage disk set-foreign-lun
- storage disk set-led
- storage disk show
- storage disk unfail
- storage disk updatefirmware
- storage disk zerospares
- storage disk error show
- storage disk firmware revert
- storage disk firmware show-update-status
- storage disk firmware update
- storage disk option modify
- storage disk option show
storage dqp commands
storage encryption commands
storage errors commands
storage failover commands
- storage failover giveback
- storage failover modify
- storage failover show-giveback
- storage failover show-takeover
- storage failover takeover
- storage failover hwassist show
- storage failover hwassist test
- storage failover hwassist stats clear
- storage failover hwassist stats show
- storage failover internal-options show
- storage failover mailbox-disk show
- storage failover progress-table show
storage firmware commands
- storage firmware download
- storage firmware acp delete
- storage firmware acp rename
- storage firmware acp show
- storage firmware disk delete
- storage firmware disk rename
- storage firmware disk show
- storage firmware hba show
- storage firmware shelf delete
- storage firmware shelf rename
- storage firmware shelf show
storage iscsi-initiator commands
storage path commands
storage pool commands
storage port commands
storage raid-options commands
storage shelf commands
- storage shelf show
- storage shelf acp configure
- storage shelf acp show
- storage shelf acp module show
- storage shelf drawer show-phy
- storage shelf drawer show-slot
- storage shelf firmware show-update-status
- storage shelf firmware update
- storage shelf location-led modify
- storage shelf location-led show
- storage shelf port show
storage tape commands
- storage tape offline
- storage tape online
- storage tape position
- storage tape reset
- storage tape show-errors
- storage tape show-media-changer
- storage tape show-supported-status
- storage tape show-tape-drive
- storage tape show
- storage tape trace
- storage tape alias clear
- storage tape alias set
- storage tape alias show
- storage tape config-file delete
- storage tape config-file get
- storage tape config-file show
- storage tape library config show
- storage tape library path show-by-initiator
- storage tape load-balance modify
- storage tape load-balance show
system commands
system bridge commands
- system bridge add
- system bridge modify
- system bridge refresh
- system bridge remove
- system bridge run-cli
- system bridge show
- system bridge config-dump collect
- system bridge config-dump delete
- system bridge config-dump show
- system bridge coredump collect
- system bridge coredump delete
- system bridge coredump show
- system bridge firmware update
- system bridge options modify
- system bridge options show
system chassis commands
system configuration commands
- system configuration backup copy
- system configuration backup create
- system configuration backup delete
- system configuration backup download
- system configuration backup rename
- system configuration backup show
- system configuration backup upload
- system configuration backup settings modify
- system configuration backup settings set-password
- system configuration backup settings show
- system configuration recovery cluster modify
- system configuration recovery cluster recreate
- system configuration recovery cluster rejoin
- system configuration recovery cluster show
- system configuration recovery cluster sync
- system configuration recovery node restore
system controller commands
- system controller show
- system controller bootmedia show-serial-number
- system controller clus-flap-threshold show
- system controller config show-errors
- system controller config pci show-add-on-devices
- system controller config pci show-hierarchy
- system controller coredump-device show-serial-number
- system controller environment show
- system controller flash-cache show
- system controller flash-cache secure-erase run
- system controller flash-cache secure-erase show
- system controller fru show-manufacturing-info
- system controller fru led disable-all
- system controller fru led enable-all
- system controller fru led modify
- system controller fru led show
- system controller hardware-license show
- system controller hardware-license update
- system controller ioxm show
- system controller location-led modify
- system controller location-led show
- system controller memory dimm show
- system controller nvram-bb-threshold show
- system controller pci show
- system controller pcicerr threshold modify
- system controller pcicerr threshold show
- system controller platform-capability show
- system controller replace cancel
- system controller replace pause
- system controller replace resume
- system controller replace show-details
- system controller replace start
- system controller service-event delete
- system controller service-event show
- system controller slot module insert
- system controller slot module remove
- system controller slot module replace
- system controller slot module show
- system controller sp config show
- system controller sp upgrade show
system feature-usage commands
system fru-check commands
system ha commands
- system ha interconnect config show
- system ha interconnect link off
- system ha interconnect link on
- system ha interconnect ood clear-error-statistics
- system ha interconnect ood clear-performance-statistics
- system ha interconnect ood disable-optimization
- system ha interconnect ood disable-statistics
- system ha interconnect ood enable-optimization
- system ha interconnect ood enable-statistics
- system ha interconnect ood send-diagnostic-buffer
- system ha interconnect ood status show
- system ha interconnect port show
- system ha interconnect statistics clear-port-symbol-error
- system ha interconnect statistics show-scatter-gather-list
- system ha interconnect statistics performance show
- system ha interconnect status show
system health commands
- system health alert delete
- system health alert modify
- system health alert show
- system health alert definition show
- system health autosupport trigger history show
- system health config show
- system health policy definition modify
- system health policy definition show
- system health status show
- system health subsystem show
system license commands
- system license add
- system license clean-up
- system license delete
- system license show-aggregates
- system license show-serial-numbers
- system license show-status
- system license update-leases
- system license capacity show
- system license entitlement-risk show
- system license license-manager check
- system license license-manager modify
- system license license-manager show
- system license status show
system node commands
- system node halt
- system node migrate-root
- system node modify
- system node reboot
- system node rename
- system node restore-backup
- system node revert-to
- system node run-console
- system node run
- system node show-discovered
- system node show
- system node autosupport invoke-core-upload
- system node autosupport invoke-diagnostic
- system node autosupport invoke-performance-archive
- system node autosupport invoke-splog
- system node autosupport modify
- system node autosupport show
- system node autosupport check show-details
- system node autosupport destinations show
- system node autosupport history cancel
- system node autosupport history retransmit
- system node autosupport history show-upload-details
- system node autosupport manifest show
- system node autosupport trigger modify
- system node autosupport trigger show
- system node coredump delete-all
- system node coredump save-all
- system node coredump show
- system node coredump status
- system node coredump trigger
- system node coredump upload
- system node coredump config modify
- system node coredump config show
- system node coredump external-device save
- system node coredump external-device show
- system node coredump reports delete
- system node coredump reports show
- system node coredump reports upload
- system node coredump segment delete-all
- system node coredump segment show
- system node environment sensors show
- system node external-cache modify
- system node external-cache show
- system node firmware download
- system node hardware nvram-encryption modify
- system node hardware nvram-encryption show
- system node hardware tape drive show
- system node hardware tape library show
- system node hardware unified-connect modify
- system node hardware unified-connect show
- system node image abort-operation
- system node image get
- system node image modify
- system node image show-update-progress
- system node image update
- system node image package delete
- system node image package show
- system node image package external-device delete
- system node image package external-device show
- system node internal-switch show
- system node internal-switch dump stat
- system node nfs usage show
- system node power on
- system node power show
- system node root-mount create
- system node root-mount delete
- system node root-mount show
- system node upgrade-revert show
- system node upgrade-revert upgrade
- system node usb-ports modify
- system node usb-ports show
- system node virtual-machine show-network-load-balancer
- system node virtual-machine disk-object-store create
- system node virtual-machine disk-object-store delete
- system node virtual-machine disk-object-store modify
- system node virtual-machine disk-object-store show
- system node virtual-machine hypervisor show
- system node virtual-machine instance show-system-disks
system script commands
system service-processor commands
- system service-processor reboot-sp
- system service-processor show
- system service-processor api-service check
- system service-processor api-service disable-installed-certificates
- system service-processor api-service enable-installed-certificates
- system service-processor api-service modify
- system service-processor api-service regenerate-ssh-auth-key
- system service-processor api-service renew-internal-certificates
- system service-processor api-service show
- system service-processor image modify
- system service-processor image show
- system service-processor image update
- system service-processor image update-progress show
- system service-processor log show-allocations
- system service-processor network modify
- system service-processor network show
- system service-processor network auto-configuration disable
- system service-processor network auto-configuration enable
- system service-processor network auto-configuration show
- system service-processor ssh add-allowed-addresses
- system service-processor ssh remove-allowed-addresses
- system service-processor ssh show
system services commands
- system services firewall modify
- system services firewall show
- system services firewall policy clone
- system services firewall policy create
- system services firewall policy delete
- system services firewall policy modify
- system services firewall policy show
- system services manager install show
- system services manager policy add
- system services manager policy remove
- system services manager policy setstate
- system services manager policy show
- system services manager status show
- system services ndmp kill-all
- system services ndmp modify
- system services ndmp off
- system services ndmp on
- system services ndmp password
- system services ndmp probe
- system services ndmp show
- system services ndmp status
- system services ndmp log start
- system services ndmp log stop
- system services ndmp node-scope-mode off
- system services ndmp node-scope-mode on
- system services ndmp node-scope-mode status
- system services ndmp service modify
- system services ndmp service show
- system services ndmp service start
- system services ndmp service stop
- system services ndmp service terminate
- system services web modify
- system services web show
- system services web node show
system smtape commands
system snmp commands
- system snmp authtrap
- system snmp contact
- system snmp enable-snmpv3
- system snmp init
- system snmp location
- system snmp prepare-to-downgrade
- system snmp show
- system snmp community add
- system snmp community delete
- system snmp community show
- system snmp traphost add
- system snmp traphost delete
- system snmp traphost show
system status commands
system switch commands
- system switch ethernet configure-health-monitor
- system switch ethernet create
- system switch ethernet delete
- system switch ethernet modify
- system switch ethernet show-all
- system switch ethernet fan show
- system switch ethernet interface show
- system switch ethernet log collect
- system switch ethernet log disable-collection
- system switch ethernet log enable-collection
- system switch ethernet log modify
- system switch ethernet log setup-password
- system switch ethernet log show
- system switch ethernet polling-interval modify
- system switch ethernet polling-interval show
- system switch ethernet power show
- system switch ethernet switch-count show
- system switch ethernet temperature show
- system switch ethernet threshold show
- system switch fibre-channel add
- system switch fibre-channel modify
- system switch fibre-channel refresh
- system switch fibre-channel remove
- system switch fibre-channel show
system timeout commands
template commands
volume commands
- volume autosize
- volume create
- volume delete
- volume expand
- volume make-vsroot
- volume modify
- volume mount
- volume offline
- volume online
- volume rehost
- volume rename
- volume restrict
- volume show-footprint
- volume show-space
- volume show
- volume size
- volume transition-prepare-to-downgrade
- volume unmount
volume activity-tracking commands
volume analytics commands
volume clone commands
- volume clone create
- volume clone show
- volume clone sharing-by-split show
- volume clone sharing-by-split undo show
- volume clone sharing-by-split undo start-all
- volume clone sharing-by-split undo stop
- volume clone split estimate
- volume clone split show
- volume clone split start
- volume clone split stop
volume conversion commands
volume efficiency commands
- volume efficiency check
- volume efficiency modify
- volume efficiency off
- volume efficiency on
- volume efficiency prepare-to-downgrade
- volume efficiency promote
- volume efficiency revert-to
- volume efficiency show
- volume efficiency start
- volume efficiency stat
- volume efficiency stop
- volume efficiency undo
- volume efficiency policy create
- volume efficiency policy delete
- volume efficiency policy modify
- volume efficiency policy show
volume encryption commands
- volume encryption conversion pause
- volume encryption conversion resume
- volume encryption conversion show
- volume encryption conversion start
- volume encryption rekey pause
- volume encryption rekey resume
- volume encryption rekey show
- volume encryption rekey start
- volume encryption secure-purge abort
- volume encryption secure-purge show
- volume encryption secure-purge start
volume file commands
- volume file compact-data
- volume file modify
- volume file privileged-delete
- volume file reservation
- volume file show-disk-usage
- volume file show-filehandle
- volume file show-inode
- volume file async-delete cancel
- volume file async-delete prepare-for-revert
- volume file async-delete show
- volume file async-delete start
- volume file async-delete client disable
- volume file async-delete client enable
- volume file async-delete client show
- volume file clone autodelete
- volume file clone create
- volume file clone show-autodelete
- volume file clone deletion add-extension
- volume file clone deletion modify
- volume file clone deletion remove-extension
- volume file clone deletion show
- volume file clone split load modify
- volume file clone split load show
- volume file fingerprint abort
- volume file fingerprint dump
- volume file fingerprint show
- volume file fingerprint start
- volume file retention show
volume flexcache commands
- volume flexcache config-refresh
- volume flexcache create
- volume flexcache delete
- volume flexcache prepare-to-downgrade
- volume flexcache show
- volume flexcache sync-properties
- volume flexcache origin show-caches
- volume flexcache origin config modify
- volume flexcache origin config show
- volume flexcache prepopulate start
volume flexgroup commands
volume inode-upgrade commands
volume move commands
volume object-store commands
volume qtree commands
volume quota commands
- volume quota modify
- volume quota off
- volume quota on
- volume quota report
- volume quota resize
- volume quota show
- volume quota policy copy
- volume quota policy create
- volume quota policy delete
- volume quota policy rename
- volume quota policy show
- volume quota policy rule create
- volume quota policy rule delete
- volume quota policy rule modify
- volume quota policy rule show
- volume quota policy rule count show
volume reallocation commands
volume rebalance commands
volume recovery-queue commands
volume schedule-style commands
volume snaplock commands
volume snapshot commands
- volume snapshot compute-reclaimable
- volume snapshot create
- volume snapshot delete
- volume snapshot modify-snaplock-expiry-time
- volume snapshot partial-restore-file
- volume snapshot prepare-for-revert
- volume snapshot rename
- volume snapshot restore-file
- volume snapshot show-delta
- volume snapshot autodelete modify
- volume snapshot autodelete show
- volume snapshot policy add-schedule
- volume snapshot policy create
- volume snapshot policy delete
- volume snapshot policy modify-schedule
- volume snapshot policy remove-schedule
- volume snapshot policy show
volume transition-convert-dir commands
vserver commands
- vserver add-aggregates
- vserver add-protocols
- vserver context
- vserver create
- vserver delete
- vserver modify
- vserver prepare-for-revert
- vserver remove-aggregates
- vserver remove-protocols
- vserver rename
- vserver restamp-msid
- vserver show-aggregates
- vserver show-protocols
- vserver show
- vserver start
- vserver stop
- vserver unlock
vserver active-directory commands
vserver audit commands
- vserver audit create
- vserver audit delete
- vserver audit disable
- vserver audit enable
- vserver audit modify
- vserver audit prepare-to-downgrade
- vserver audit rotate-log
- vserver audit show
- vserver audit audit-log-redirect create
- vserver audit audit-log-redirect delete
- vserver audit audit-log-redirect modify
- vserver audit audit-log-redirect show
vserver check commands
vserver cifs commands
- vserver cifs add-netbios-aliases
- vserver cifs check
- vserver cifs create
- vserver cifs delete
- vserver cifs modify
- vserver cifs nbtstat
- vserver cifs prepare-to-downgrade
- vserver cifs remove-netbios-aliases
- vserver cifs repair-modify
- vserver cifs security-encryption-required-dc-connections-prepare-to-downgrade
- vserver cifs show
- vserver cifs start
- vserver cifs stop
- vserver cifs branchcache create
- vserver cifs branchcache delete
- vserver cifs branchcache hash-create
- vserver cifs branchcache hash-flush
- vserver cifs branchcache modify
- vserver cifs branchcache show
- vserver cifs cache name-to-sid delete-all
- vserver cifs cache name-to-sid show
- vserver cifs cache settings modify
- vserver cifs cache settings show
- vserver cifs cache sid-to-name delete-all
- vserver cifs cache sid-to-name show
- vserver cifs character-mapping create
- vserver cifs character-mapping delete
- vserver cifs character-mapping modify
- vserver cifs character-mapping show
- vserver cifs connection show
- vserver cifs domain discovered-servers reset-servers
- vserver cifs domain discovered-servers show
- vserver cifs domain discovered-servers discovery-mode modify
- vserver cifs domain discovered-servers discovery-mode show
- vserver cifs domain name-mapping-search add
- vserver cifs domain name-mapping-search modify
- vserver cifs domain name-mapping-search remove
- vserver cifs domain name-mapping-search show
- vserver cifs domain password change
- vserver cifs domain password reset
- vserver cifs domain password schedule modify
- vserver cifs domain password schedule show
- vserver cifs domain preferred-dc add
- vserver cifs domain preferred-dc check
- vserver cifs domain preferred-dc remove
- vserver cifs domain preferred-dc show
- vserver cifs domain trusts rediscover
- vserver cifs domain trusts show
- vserver cifs group-policy modify
- vserver cifs group-policy show-applied
- vserver cifs group-policy show-defined
- vserver cifs group-policy update
- vserver cifs group-policy central-access-policy show-applied
- vserver cifs group-policy central-access-policy show-defined
- vserver cifs group-policy central-access-rule show-applied
- vserver cifs group-policy central-access-rule show-defined
- vserver cifs group-policy restricted-group show-applied
- vserver cifs group-policy restricted-group show-defined
- vserver cifs home-directory modify
- vserver cifs home-directory show-user
- vserver cifs home-directory search-path add
- vserver cifs home-directory search-path remove
- vserver cifs home-directory search-path reorder
- vserver cifs home-directory search-path show
- vserver cifs options modify
- vserver cifs options show
- vserver cifs security modify
- vserver cifs security show
- vserver cifs session close
- vserver cifs session show
- vserver cifs session file close
- vserver cifs session file show
- vserver cifs share create
- vserver cifs share delete
- vserver cifs share modify
- vserver cifs share show
- vserver cifs share access-control create
- vserver cifs share access-control delete
- vserver cifs share access-control modify
- vserver cifs share access-control show
- vserver cifs share properties add
- vserver cifs share properties remove
- vserver cifs share properties show
- vserver cifs superuser create
- vserver cifs superuser delete
- vserver cifs superuser show
- vserver cifs symlink create
- vserver cifs symlink delete
- vserver cifs symlink modify
- vserver cifs symlink show
- vserver cifs users-and-groups remove-stale-records
- vserver cifs users-and-groups update-names
- vserver cifs users-and-groups local-group add-members
- vserver cifs users-and-groups local-group create
- vserver cifs users-and-groups local-group delete
- vserver cifs users-and-groups local-group modify
- vserver cifs users-and-groups local-group remove-members
- vserver cifs users-and-groups local-group rename
- vserver cifs users-and-groups local-group show-members
- vserver cifs users-and-groups local-user create
- vserver cifs users-and-groups local-user delete
- vserver cifs users-and-groups local-user modify
- vserver cifs users-and-groups local-user rename
- vserver cifs users-and-groups local-user set-password
- vserver cifs users-and-groups local-user show-membership
- vserver cifs users-and-groups privilege add-privilege
- vserver cifs users-and-groups privilege remove-privilege
- vserver cifs users-and-groups privilege reset-privilege
- vserver cifs users-and-groups privilege show
vserver config-replication commands
vserver export-policy commands
- vserver export-policy check-access
- vserver export-policy copy
- vserver export-policy create
- vserver export-policy delete
- vserver export-policy rename
- vserver export-policy show
- vserver export-policy access-cache flush
- vserver export-policy access-cache show-rules
- vserver export-policy access-cache config modify-all-vservers
- vserver export-policy access-cache config show-all-vservers
- vserver export-policy cache flush
- vserver export-policy config-checker show
- vserver export-policy config-checker start
- vserver export-policy config-checker stop
- vserver export-policy config-checker rule delete
- vserver export-policy config-checker rule show
- vserver export-policy netgroup check-membership
- vserver export-policy netgroup cache show
- vserver export-policy netgroup queue show
- vserver export-policy rule add-clientmatches
- vserver export-policy rule create
- vserver export-policy rule delete
- vserver export-policy rule modify
- vserver export-policy rule remove-clientmatches
- vserver export-policy rule setindex
- vserver export-policy rule show
vserver fcp commands
- vserver fcp create
- vserver fcp delete
- vserver fcp modify
- vserver fcp show
- vserver fcp start
- vserver fcp stop
- vserver fcp initiator show
- vserver fcp interface show
- vserver fcp nameserver show
- vserver fcp ping-igroup show
- vserver fcp ping-initiator show
- vserver fcp portname set
- vserver fcp portname show
- vserver fcp topology show
- vserver fcp wwn blacklist show
- vserver fcp wwpn-alias remove
- vserver fcp wwpn-alias set
- vserver fcp wwpn-alias show
vserver fpolicy commands
- vserver fpolicy disable
- vserver fpolicy enable
- vserver fpolicy engine-connect
- vserver fpolicy engine-disconnect
- vserver fpolicy show-enabled
- vserver fpolicy show-engine
- vserver fpolicy show-passthrough-read-connection
- vserver fpolicy policy create
- vserver fpolicy policy delete
- vserver fpolicy policy modify
- vserver fpolicy policy show
- vserver fpolicy policy event create
- vserver fpolicy policy event delete
- vserver fpolicy policy event modify
- vserver fpolicy policy event show
- vserver fpolicy policy external-engine create
- vserver fpolicy policy external-engine delete
- vserver fpolicy policy external-engine modify
- vserver fpolicy policy external-engine show
- vserver fpolicy policy scope create
- vserver fpolicy policy scope delete
- vserver fpolicy policy scope modify
- vserver fpolicy policy scope show
vserver http-proxy commands
vserver iscsi commands
- vserver iscsi create
- vserver iscsi delete
- vserver iscsi modify
- vserver iscsi show
- vserver iscsi start
- vserver iscsi stop
- vserver iscsi command show
- vserver iscsi connection show
- vserver iscsi connection shutdown
- vserver iscsi initiator show
- vserver iscsi interface disable
- vserver iscsi interface enable
- vserver iscsi interface modify
- vserver iscsi interface show
- vserver iscsi interface accesslist add
- vserver iscsi interface accesslist remove
- vserver iscsi interface accesslist show
- vserver iscsi isns create
- vserver iscsi isns delete
- vserver iscsi isns modify
- vserver iscsi isns show
- vserver iscsi isns start
- vserver iscsi isns stop
- vserver iscsi isns update
- vserver iscsi security add-initator-address-ranges
- vserver iscsi security create
- vserver iscsi security default
- vserver iscsi security delete
- vserver iscsi security modify
- vserver iscsi security prepare-to-downgrade
- vserver iscsi security remove-initator-address-ranges
- vserver iscsi security show
- vserver iscsi session show
- vserver iscsi session shutdown
- vserver iscsi session parameter show
vserver locks commands
vserver migrate commands
vserver name-mapping commands
vserver nfs commands
- vserver nfs create
- vserver nfs delete
- vserver nfs modify
- vserver nfs off
- vserver nfs on
- vserver nfs prepare-for-v3-ms-dos-client-downgrade
- vserver nfs prepare-to-downgrade
- vserver nfs show
- vserver nfs start
- vserver nfs status
- vserver nfs stop
- vserver nfs connected-clients show
- vserver nfs credentials count
- vserver nfs credentials flush
- vserver nfs credentials show
- vserver nfs kerberos interface disable
- vserver nfs kerberos interface enable
- vserver nfs kerberos interface modify
- vserver nfs kerberos interface show
- vserver nfs kerberos realm create
- vserver nfs kerberos realm delete
- vserver nfs kerberos realm modify
- vserver nfs kerberos realm show
- vserver nfs pnfs devices create
- vserver nfs pnfs devices delete
- vserver nfs pnfs devices show
- vserver nfs pnfs devices cache show
- vserver nfs pnfs devices mappings show
vserver nvme commands
- vserver nvme create
- vserver nvme delete
- vserver nvme modify
- vserver nvme show-discovery-controller
- vserver nvme show-interface
- vserver nvme show
- vserver nvme feature show
- vserver nvme namespace convert-from-lun
- vserver nvme namespace create
- vserver nvme namespace delete
- vserver nvme namespace modify
- vserver nvme namespace show
- vserver nvme subsystem create
- vserver nvme subsystem delete
- vserver nvme subsystem modify
- vserver nvme subsystem show
- vserver nvme subsystem controller show
- vserver nvme subsystem host add
- vserver nvme subsystem host remove
- vserver nvme subsystem host show
- vserver nvme subsystem map add
- vserver nvme subsystem map remove
- vserver nvme subsystem map show
vserver object-store-server commands
- vserver object-store-server create
- vserver object-store-server delete
- vserver object-store-server modify
- vserver object-store-server show
- vserver object-store-server audit create
- vserver object-store-server audit delete
- vserver object-store-server audit disable
- vserver object-store-server audit enable
- vserver object-store-server audit modify
- vserver object-store-server audit rotate-log
- vserver object-store-server audit show
- vserver object-store-server audit event-selector create
- vserver object-store-server audit event-selector delete
- vserver object-store-server audit event-selector modify
- vserver object-store-server audit event-selector show
- vserver object-store-server bucket create
- vserver object-store-server bucket delete
- vserver object-store-server bucket evict-remote-cached-objects
- vserver object-store-server bucket modify
- vserver object-store-server bucket show
- vserver object-store-server bucket policy-statement-condition create
- vserver object-store-server bucket policy-statement-condition delete
- vserver object-store-server bucket policy-statement-condition modify
- vserver object-store-server bucket policy-statement-condition show
- vserver object-store-server bucket policy statement create
- vserver object-store-server bucket policy statement delete
- vserver object-store-server bucket policy statement modify
- vserver object-store-server bucket policy statement show
- vserver object-store-server group create
- vserver object-store-server group delete
- vserver object-store-server group modify
- vserver object-store-server group show
- vserver object-store-server policy create
- vserver object-store-server policy delete
- vserver object-store-server policy modify
- vserver object-store-server policy show
- vserver object-store-server policy statement create
- vserver object-store-server policy statement delete
- vserver object-store-server policy statement modify
- vserver object-store-server policy statement show
- vserver object-store-server user create
- vserver object-store-server user delete
- vserver object-store-server user modify
- vserver object-store-server user regenerate-keys
- vserver object-store-server user show
vserver peer commands
- vserver peer accept
- vserver peer create
- vserver peer delete
- vserver peer modify-local-name
- vserver peer reject
- vserver peer repair-peer-name
- vserver peer resume
- vserver peer show-all
- vserver peer show
- vserver peer suspend
- vserver peer permission create
- vserver peer permission delete
- vserver peer permission modify
- vserver peer permission show
- vserver peer transition create
- vserver peer transition delete
- vserver peer transition modify
- vserver peer transition show
vserver san commands
vserver security commands
- vserver security file-directory apply
- vserver security file-directory remove-slag
- vserver security file-directory show-effective-permissions
- vserver security file-directory job show
- vserver security file-directory ntfs create
- vserver security file-directory ntfs delete
- vserver security file-directory ntfs modify
- vserver security file-directory ntfs show
- vserver security file-directory ntfs dacl add
- vserver security file-directory ntfs dacl modify
- vserver security file-directory ntfs dacl remove
- vserver security file-directory ntfs dacl show
- vserver security file-directory ntfs sacl add
- vserver security file-directory ntfs sacl modify
- vserver security file-directory ntfs sacl remove
- vserver security file-directory ntfs sacl show
- vserver security file-directory policy create
- vserver security file-directory policy delete
- vserver security file-directory policy show
- vserver security file-directory policy task add
- vserver security file-directory policy task modify
- vserver security file-directory policy task remove
- vserver security file-directory policy task show
- vserver security trace filter create
- vserver security trace filter delete
- vserver security trace filter modify
- vserver security trace filter show
- vserver security trace trace-result delete
- vserver security trace trace-result show
vserver services commands
- vserver services access-check authentication get-claim-name
- vserver services access-check authentication get-dc-info
- vserver services access-check authentication login-cifs
- vserver services access-check authentication ontap-admin-ldap-fastbind
- vserver services access-check authentication ontap-admin-login-cifs
- vserver services access-check authentication show-creds
- vserver services access-check authentication show-ontap-admin-unix-creds
- vserver services access-check authentication sid-to-uid
- vserver services access-check authentication sid-to-unix-name
- vserver services access-check authentication translate
- vserver services access-check authentication uid-to-sid
- vserver services access-check dns forward-lookup
- vserver services access-check dns srv-lookup
- vserver services access-check name-mapping show
- vserver services access-check server-discovery reset
- vserver services access-check server-discovery show-host
- vserver services access-check server-discovery show-site
- vserver services access-check server-discovery test
- vserver services name-service cache group-membership delete-all
- vserver services name-service cache group-membership show
- vserver services name-service cache group-membership settings modify
- vserver services name-service cache group-membership settings show
- vserver services name-service cache hosts forward-lookup delete-all
- vserver services name-service cache hosts forward-lookup show
- vserver services name-service cache hosts reverse-lookup delete-all
- vserver services name-service cache hosts reverse-lookup show
- vserver services name-service cache hosts settings modify
- vserver services name-service cache hosts settings show
- vserver services name-service cache netgroups ip-to-netgroup delete-all
- vserver services name-service cache netgroups ip-to-netgroup show
- vserver services name-service cache netgroups members delete-all
- vserver services name-service cache netgroups members show
- vserver services name-service cache netgroups settings modify
- vserver services name-service cache netgroups settings show
- vserver services name-service cache settings modify
- vserver services name-service cache settings show
- vserver services name-service cache unix-group group-by-gid delete-all
- vserver services name-service cache unix-group group-by-gid show
- vserver services name-service cache unix-group group-by-name delete-all
- vserver services name-service cache unix-group group-by-name show
- vserver services name-service cache unix-group settings modify
- vserver services name-service cache unix-group settings show
- vserver services name-service cache unix-user settings modify
- vserver services name-service cache unix-user settings show
- vserver services name-service cache unix-user user-by-id delete-all
- vserver services name-service cache unix-user user-by-id show
- vserver services name-service cache unix-user user-by-name delete-all
- vserver services name-service cache unix-user user-by-name show
- vserver services name-service dns check
- vserver services name-service dns create
- vserver services name-service dns delete
- vserver services name-service dns modify
- vserver services name-service dns show
- vserver services name-service dns dynamic-update modify
- vserver services name-service dns dynamic-update prepare-to-downgrade
- vserver services name-service dns dynamic-update show
- vserver services name-service dns dynamic-update record add
- vserver services name-service dns dynamic-update record delete
- vserver services name-service dns hosts create
- vserver services name-service dns hosts delete
- vserver services name-service dns hosts modify
- vserver services name-service dns hosts show
- vserver services name-service getxxbyyy getaddrinfo
- vserver services name-service getxxbyyy getgrbygid
- vserver services name-service getxxbyyy getgrbyname
- vserver services name-service getxxbyyy getgrlist
- vserver services name-service getxxbyyy gethostbyaddr
- vserver services name-service getxxbyyy gethostbyname
- vserver services name-service getxxbyyy getnameinfo
- vserver services name-service getxxbyyy getpwbyname
- vserver services name-service getxxbyyy getpwbyuid
- vserver services name-service getxxbyyy netgrpcheck
- vserver services name-service ldap check
- vserver services name-service ldap create
- vserver services name-service ldap delete
- vserver services name-service ldap modify
- vserver services name-service ldap show
- vserver services name-service ldap client create
- vserver services name-service ldap client delete
- vserver services name-service ldap client modify-bind-password
- vserver services name-service ldap client show
- vserver services name-service ldap client schema copy
- vserver services name-service ldap client schema delete
- vserver services name-service ldap client schema modify
- vserver services name-service ldap client schema show
- vserver services name-service netgroup load
- vserver services name-service netgroup status
- vserver services name-service netgroup file delete
- vserver services name-service netgroup file show
- vserver services name-service nis-domain create
- vserver services name-service nis-domain delete
- vserver services name-service nis-domain modify
- vserver services name-service nis-domain show-bound
