      security key-manager onboard enable
Enable onboard key manager
This command enables the onboard key manager for the admin Vserver.
[-cc-mode-enabled {yes|no}]- Enable Common Criteria Mode?-
Use this parameter to specify whether the Common Critieria (CC) mode should be enabled or not. When CC mode is enabled, you are required to provide a cluster passphrase that is between 64 and 256 ASCII character long, and you are required to enter that passphrase each time a node reboots. CC mode cannot be enabled in a MetroCluster configuration.
The following example enables the Onboard Key Manager for the admin Vserver cluster-1:
cluster-1::> security key-manager onboard enable Enter the cluster-wide passphrase for onboard key management: Re-enter the cluster-wide passphrase: After configuring onboard key management, save the encrypted configuration data in a safe location so that you can use it if you need to perform a manual recovery operation. To view the data, use the "security key-manager onboard show-backup" command.
