vserver services web access show
Display web service authorization for user roles
This command displays the roles that are authorized to access the Vserver’s web services. For the user to access services that require authentication, the user’s roles, as defined by security login show , must be included in this configuration.
Note Node Vserver services are authorized with the data Vserver’s roles.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver
Identifies a Vserver for hosting a specific web service.
[-name <text>] - Service Name
Identifies the name of the web service.
[-role <text>] - Role Name
Identifies a role assigned for accessing the service. A service without any authorizations has a role of 'none' assigned to it automatically.
[-type <vserver type>] - Type of Vserver
Identifies the type of Vserver on which the service is hosted.
The following example displays the roles that are authorized to access the web services.
cluster1::vserver services web access> show
Vserver        Type     Service Name     Role
cluster1       admin    cem              none
cluster1       admin    ontapi           readonly
cluster1       admin    portal           none
cluster1       admin    spi              none
cluster1       admin    supdiag          none
vs0            cluster  ontapi           admin
6 entries were displayed.
