vserver services web access show
Display web service authorization for user roles
This command displays the roles that are authorized to access the Vserver's web services. For the user to access services that require authentication, the user's roles, as defined by security login show , must be included in this configuration.
Node Vserver services are authorized with the data Vserver's roles. |
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver-
Identifies a Vserver for hosting a specific web service.
[-name <text>]
- Service Name-
Identifies the name of the web service.
[-role <text>]
- Role Name-
Identifies a role assigned for accessing the service. A service without any authorizations has a role of 'none' assigned to it automatically.
[-type <vserver type>]
- Type of Vserver-
Identifies the type of Vserver on which the service is hosted.
The following example displays the roles that are authorized to access the web services.
cluster1::vserver services web access> show Vserver Type Service Name Role -------------- -------- ---------------- ---------------- cluster1 admin cem none cluster1 admin ontapi readonly cluster1 admin portal none cluster1 admin spi none cluster1 admin supdiag none vs0 cluster ontapi admin 6 entries were displayed. cluster1::vserver services web access>
