vserver vscan on-demand-task show
Display On-Demand tasks
The vserver vscan on-demand-task show command displays information about the On-Demand tasks belonging to the Vserver. If you do not specify any parameters, the command displays the following information about all On-Demand tasks:
  • Vserver name
  • Task name
  • Scan paths
  • Report directory path
  • Schedule
You can specify the -fields parameter to specify which fields of information to display about On-Demand tasks. In addition to the fields above, you can display the following fields:
  • Max file size
  • File paths to exclude
  • File extensions to exclude
  • File extensions to include
  • Scan files without extension
  • Scan timeout
  • Cross junction
  • Directory recursion
  • Scan priority
  • Report log level
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
If you specify this parameter, the command displays information only about the On-Demand tasks for the specified Vserver.
[-task-name <text>] - Task Name
If you specify this parameter, the command displays information only about the specified On-Demand task.
[-scan-paths <text>,…​] - List of Scan Paths
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified path or paths in the scan-paths list.
[-report-directory <text>] - Report Directory Path
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified report-directory.
[-schedule <text>] - Job Schedule
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified schedule.
[-max-file-size {<integer>[KB|MB|GB|TB|PB]}] - Max File Size Allowed for Scanning
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified max-file-size.
[-paths-to-exclude <text>,…​] - File Paths Not to Scan
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified path or paths in the exclude list.
[-file-ext-to-exclude <File extension>,…​] - File Extensions Not to Scan
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified file extension or extensions in the exclude list.
[-file-ext-to-include <File extension>,…​] - File Extensions to Scan
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified file extension or extensions in the include list.
[-scan-files-with-no-ext {true|false}] - Scan Files with No Extension
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified value.
[-request-timeout <[<integer>h][<integer>m][<integer>s]>] - Request Service Timeout
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified request-timeout.
[-cross-junction {true|false}] - Cross Junction
[-directory-recursion {true|false}] - Directory Recursion
[-scan-priority {low|normal}] - Scan Priority
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified scan-priority.
[-report-log-level {verbose|info|error}] - Report Log Level
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified report-log-level.
[-report-expiry-time <[<integer>h][<integer>m][<integer>s]>] - Expiration Time for Report
This parameter specifies the expiration time for the reports generated by On-Demand scans. Once this time elapses, the reports are auto-deleted. The default value is 0, which means reports are retained until they are manually deleted.
The following example displays information about all On-Demand tasks:
cluster1::> vserver vscan on-demand-task show
                                             Report
Vserver     Task Name   Scan Paths           Directory Path    Schedule
vs1         t1          /test                /report           -
vs2         t2          /, /test/            /report           daily
2 entries were displayed.
The following example displays detailed information about an On-Demand task:
cluster1::> vserver vscan on-demand-task show -instance -vserver vs1 -task-name t1
Vserver: vs1
                         Task Name: t1
                List of Scan Paths: /test
             Report Directory Path: /report
                      Job Schedule: -
Max File Size Allowed for Scanning: 2GB
            File Paths Not to Scan: /vol1/cold-files/
       File Extensions Not to Scan: mp3, mp4
           File Extensions to Scan: *
      Scan Files with No Extension: true
           Request Service Timeout: 1m
                    Cross Junction: true
               Directory Recursion: true
                     Scan Priority: low
                  Report Log Level: verbose
