system ha interconnect status show
Display the high-availability interconnect connection status
The system ha interconnect status show command displays the high-availability interconnect connection status. Connection status information displayed by this command varies by controller model. For nodes with two HA interconnect links over the backplane or connected externally, this command displays the following information:
Node
Link status on the first port
Link status on the second port
Is the link on first port active?
Is the link on second port active?
Interconnect RDMA status
For nodes with a single HA interconnect link, this command displays following the information:
Node
Link status
Running the command with the -instance or -node parameter displays detailed information about the interconnect device and its ports.
[-fields <fieldname>,…] -
If you specify the
-fields <fieldname>,…parameter, the command displays only the fields that you specify. - |
[-instance ]} -
Use this parameter to display all the fields for the specified node or all the nodes.
[-node {<nodename>|local}]- Node (privilege: advanced)-
Use this parameter to display all the fields for the specified node.
[-link-status {up|down}]- Link Status (privilege: advanced)-
Selects the nodes that match this parameter value. The value
upmeans link is online. [-link0-status {up|down}]- Link 0 Status (privilege: advanced)-
upmeans link is online. [-link1-status {up|down}]- Link 1 Status (privilege: advanced)-
upmeans link is online. [-ic-rdma {up|down}]- IC RDMA Connection (privilege: advanced)-
upmeans active interconnect connection with its partner. [-is-link0-active {true|false}]- Is Link 0 Active (privilege: advanced)-
truemeans the interconnect data channels are established on this link. [-is-link1-active {true|false}]- Is Link 1 Active (privilege: advanced)-
truemeans the interconnect data channels are established on this link. [-slot <integer>]- Slot Number (privilege: advanced)-
Selects the nodes that match this PCI slot number.
[-driver-name <text>]- Driver Name (privilege: advanced)-
Selects the nodes that match this interconnect device driver name.
[-firmware <text>]- Firmware Revision (privilege: advanced)-
Selects the nodes that match this firmware version.
[-version <text>]- Version Number (privilege: advanced)-
[-device-type <text>]- Device Type (privilege: advanced)-
Selects the nodes that match this interconnect device type.
[-serial-number <text>]- Serial Number (privilege: advanced)-
Selects the nodes that match this interconnect device serial number.
[-debug-firmware {yes|no}]- Debug Firmware (privilege: advanced)-
[-command-revision <integer>]- Command Revision (privilege: advanced)-
Selects the nodes that match this interconnect device command revision.
[-hardware-revision <integer>]- Hardware Revision (privilege: advanced)-
Selects the nodes that match this interconnect device hardware revision.
[-port1 <integer>]- Port Number 1 (privilege: advanced)-
[-port1-port-name <text>]- Port Name (privilege: advanced)-
Selects the nodes that match this port name.
[-port1-gid <text>]- Global Identifier (privilege: advanced)-
Selects the nodes that match this global identifier value.
[-port1-base-lid <text>]- Base Local Identifier (privilege: advanced)-
Selects the nodes that match this base local identifier value.
[-port1-rm-lid <text>]- Remote Local Identifier (privilege: advanced)-
Selects the nodes that match this remote local identifier value.
[-port1-mtu <integer>]- Maximum Transmission Unit (privilege: advanced)-
[-port1-data-rate <text>]- Data Rate (privilege: advanced)-
[-port1-link-info <text>]- Link Information (privilege: advanced)-
[-port1-qsfp-vendor <text>]- QSFP Vendor (privilege: advanced)-
Selects the nodes that match this QSFP (Quad Small Form-factor Pluggable) vendor name.
[-port1-qsfp-part-number <text>]- QSFP Part Number (privilege: advanced)-
Selects the nodes that match this QSFP (Quad Small Form-factor Pluggable) part-number.
[-port1-qsfp-type <text>]- QSFP Type (privilege: advanced)-
Selects the nodes that match this QSFP (Quad Small Form-factor Pluggable) type.
[-port1-qsfp-serial-number <text>]- QSFP Serial Number (privilege: advanced)-
Selects the nodes that match this QSFP (Quad Small Form-factor Pluggable) serial number.
[-port2 <integer>]- Port Number 2 (privilege: advanced)-
[-port2-port-name <text>]- Port Name (privilege: advanced)-
[-port2-gid <text>]- Global Identifier (privilege: advanced)-
[-port2-base-lid <text>]- Base Local Identifier (privilege: advanced)-
[-port2-rm-lid <text>]- Remote Local Identifier (privilege: advanced)-
[-port2-mtu <integer>]- Maximum Transmission Unit (privilege: advanced)-
[-port2-data-rate <text>]- Data Rate (privilege: advanced)-
[-port2-link-info <text>]- Link Information (privilege: advanced)-
[-port2-qsfp-vendor <text>]- QSFP Vendor (privilege: advanced)-
[-port2-qsfp-part-number <text>]- QSFP Part Number (privilege: advanced)-
Selects the nodes that match this QSFP (Quad Small Form-factor Pluggable) part number.
[-port2-qsfp-type <text>]- QSFP Type (privilege: advanced)-
[-port2-qsfp-serial-number <text>]- QSFP Serial Number (privilege: advanced)-
The following example displays status information about the HA interconnect connection on FAS8000 series nodes with two HA interconnect links in the cluster:
cluster1::*> system ha interconnect status show
Node: ic-f8040-01
Link 0 Status: up
Link 1 Status: up
Is Link 0 Active: true
Is Link 1 Active: false
IC RDMA Connection: up
Node: ic-f8040-02
Link 0 Status: up
Link 1 Status: up
2 entries were displayed.
The following example displays status information about the HA interconnect connection on FAS2500 series nodes with a single HA interconnect link in the cluster:
Node: ic-f2554-01
Link Status: up
Node: ic-f2554-02
Link Status: up
The following example displays detailed information about the HA interconnect link when parameters like -instance , -node are used with the `system ha interconnect status show ` command
cluster1::*> system ha interconnect status show -instance -node ic-f8040-01
Node: ic-f8040-01
Link 0 Status: up
Link 1 Status: up
Slot: 0
Driver Name: IB Host Adapter i0 (Mellanox ConnectX MT27518 rev. 0)
Firmware: 2.11.534
Debug Firmware: no
Interconnect Port 0 :
Port Name: ib0a
GID: fe80:0000:0000:0000:00a0:9800:0030:33ec
Base LID: 0x3ec
MTU: 4096
Data Rate: 40 Gb/s (4X) QDR
Link Information: ACTIVE
Interconnect Port 1 :
Port Name: ib0b
GID: fe80:0000:0000:0000:00a0:9800:0030:33ed
Base LID: 0x3ed
MTU: 4096
