network interface start-cluster-check
(DEPRECATED)-Use the network interface check cluster-connectivity start command
Note This command has been deprecated and may be removed in a future version of ONTAP. Use the network interface check cluster-connectivity start command instead.
The network interface start-cluster-check command initiates an accessibility check from every logical interface to every aggregate. Automatic checks run periodically, but this command manually initiates a check immediately.
This command produces no direct output. Any errors encountered during the check are reported in the event log. See the event log show command for more information.
This example shows an execution of this command, with all parameters and output.
cluster1::> network interface start-cluster-check
