cluster agent connection show
Display agent connections
This command displays the connections that have been established to help external managers manage the cluster.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-name <text>]- Name (privilege: advanced)-
Selects the connections that match the supplied name.
[-uuid <UUID>]- UUID (privilege: advanced)-
Selects the connections that match the supplied uuid.
[-destination <text>]- Destination URL (privilege: advanced)-
Selects the connections that match the supplied desination.
[-state {connecting|connected|error|disabled|partial}]- State (privilege: advanced)-
Selects the connections that match the supplied state. The state can have one of the following values:
connecting - The agent is in the process of establishing the connection.
connected - The connection is up and active.
error - The connection is down due to a problem. See error-message and error-time for details.
disabled - The connection has been administratively disabled.
[-use-proxy {true|false}]- Use Proxy (privilege: advanced)-
Establish this connection through an HTTP Proxy server associated with this connection's IPspace
[-subscribe-address <text>]- Subscribe Address (privilege: advanced)-
AMQP address to which ONTAP will subscribe. Defaults to "ontap.agent.manager".
[-publish-address <text>]- Publish Address (privilege: advanced)-
AMQP address to which ONTAP will publish. Defaults to "ontap.agent.cluster".
[-certificate-uuid <UUID>]- Auth Certificate UUID (privilege: advanced)-
Selects the connections that match the supplied certificate-uuid.
[-certificate-name <text>]- Auth Certificate Name (privilege: advanced)-
Selects the connections that match the supplied certificate-name
[-csr-url <text>]- Auth CSR URL (privilege: advanced)-
URL to send certicate signing request (CSR) that will be used for authenticating with the destination.
[-manager-token <text>]- Manager Token (privilege: advanced)-
Selects the connections that match the supplied manager-token.
[-ipspace <IPspace>]- IPspace for connection (privilege: advanced)-
The IPspace to use for the connection
[-error-code <integer>]- Last Error Code (privilege: advanced)-
Selects the connections that match the supplied error-code.
[-error-message <text>]- Last Error Message (privilege: advanced)-
Selects the connections that match the supplied error-message.
[-error-time <MM/DD/YYYY HH:MM:SS>]- Last Error Time (privilege: advanced)-
Selects the connections that match the supplied error-time.
[-node <nodename>]- Node owning the connection (privilege: advanced)-
The node owning the connection
[-msg-recv-total <integer>]- Total messages received from manager (privilege: advanced)-
[-msg-recv-manifest <integer>]- Total manifest messages received from manager (privilege: advanced)-
[-msg-recv-baseline-request <integer>]- Total baseline.request messages received from manager (privilege: advanced)-
[-msg-recv-counters-request <integer>]- Total counters.request messages received from manager (privilege: advanced)-
[-msg-recv-connection-status <integer>]- Total connection status messages received from manager (privilege: advanced)-
[-msg-recv-connection-modify <integer>]- Total connection modify messages received from manager (privilege: advanced)-
[-msg-recv-unknown <integer>]- Total unknown messages received from manager (privilege: advanced)-
[-msg-send-total <integer>]- Total messages sent to manager (privilege: advanced)-
[-msg-send-manifest-request <integer>]- Total manifest.request messages sent to manager (privilege: advanced)-
[-msg-send-baseline <integer>]- Total baseline messages sent to manager (privilege: advanced)-
[-msg-send-counters <integer>]- Total counters messages sent to manager (privilege: advanced)-
[-msg-send-connection-status <integer>]- Total connection status messages sent to manager (privilege: advanced)-
[-msg-send-errors <integer>]- Total error messages sent to manager (privilege: advanced)-
[-msg-delivery-errors <integer>]- Total errors encountered attempting to send/receive (privilege: advanced)-
[-msg-connection-total <integer>]- Total connection attempts (privilege: advanced)-
[-msg-connection-errors <integer>]- Total connection errors (privilege: advanced)-
[-msg-transport-errors <integer>]- Total transport errors (privilege: advanced)-
[-application <text>]- Client Application (privilege: advanced)-
Selects the connections that match the supplied application.
[-application-url <text>]- App URL (privilege: advanced)-
Selects the connections that match the supplied application-url.
[-idle-timeout <integer>]- Idle Timeout (privilege: advanced)-
AMQP idle timeout. Defaults to 0. If set, the local peer will disconnect if it does not receive AMQP frames within the timeout
[-address-family {unknown|ipv4|ipv6}]- Address Family (privilege: advanced)-
Specify address family.
cluster-1::> cluster agent connection show Name Destination State Application Use Proxy ------------- ----------------------------- ---------- -------------- --------- cloudinsights amqpws://172.31.50.251 connected Cloud Insights false
