Command reference
cluster agent connection show
Display Cloud Agent connections
This command displays the connections that have been established to help external managers manage the cluster.
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
[-name <text>] - Name (privilege: advanced)
Selects the connections that match the supplied name.
[-uuid <UUID>] - UUID (privilege: advanced)
Selects the connections that match the supplied UUID.
[-destination <text>] - Destination URL (privilege: advanced)
Selects the connections that match the supplied destination.
[-state {connecting|connected|error|disabled|partial|static}] - State (privilege: advanced)
Selects the connections that match the supplied state. The state can have one of the following values:
  • connecting - The agent is in the process of establishing the connection.
  • connected - The connection is up and active.
  • error - The connection is down due to a problem. See error-message and error-time for details.
  • disabled - The connection has been administratively disabled.
  • partial - The connection has been partially established and is not ready to deliver messages.
  • static - The agent is of static instance type and does not require an external connection.
[-use-proxy {true|false}] - Use Proxy (privilege: advanced)
Establish this connection through an HTTP proxy server associated with this connection's IPspace
[-subscribe-address <text>] - Subscribe Address (privilege: advanced)
AMQP address to which ONTAP will subscribe. Defaults to "ontap.agent.manager".
[-publish-address <text>] - Publish Address (privilege: advanced)
AMQP address to which ONTAP will publish. Defaults to "ontap.agent.cluster".
[-certificate-uuid <UUID>] - Authentication Certificate UUID (privilege: advanced)
Selects the connections that match the supplied certificate UUID.
[-csr-url <text>] - Authentication CSR URL (privilege: advanced)
URL to send certificate signing request (CSR) that will be used for authenticating with the destination.
[-manager-token <text>] - Manager Token (privilege: advanced)
Selects the connections that match the supplied manager token.
[-ipspace <IPspace>] - IPspace for Connection (privilege: advanced)
The IPspace to use for the connection
[-error-code <integer>] - Last Error Code (privilege: advanced)
Selects the connections that match the supplied error code.
[-error-message <text>] - Last Error Message (privilege: advanced)
Selects the connections that match the supplied error message.
[-error-time <MM/DD/YYYY HH:MM:SS>] - Last Error Time (privilege: advanced)
Selects the connections that match the supplied error time.
[-node <nodename>] - Node Owning the Connection (privilege: advanced)
The node owning the connection
[-msg-recv-total <integer>] - Total Messages Received from Manager (privilege: advanced)
Total messages received from manager
[-msg-recv-manifest <integer>] - Total Manifest Messages Received from Manager (privilege: advanced)
Total manifest messages received from manager
[-msg-recv-baseline-request <integer>] - Total baseline.request Messages Received from Manager (privilege: advanced)
Total baseline.request messages received from manager
[-msg-recv-counters-request <integer>] - Total counters.request Messages Received from Manager (privilege: advanced)
Total counters.request messages received from manager
[-msg-recv-connection-status <integer>] - Total Connection Status Messages Received from Manager (privilege: advanced)
Total connection status messages received from manager
[-msg-recv-connection-modify <integer>] - Total Connection Modify Messages Received from Manager (privilege: advanced)
Total connection modify messages received from manager
[-msg-recv-agent-status <integer>] - Total agent.status.request Messages Received from Manager (privilege: advanced)
Total agent.status.request Messages received from Manager
[-msg-recv-subscription-create <integer>] - Total Subscription Create Messages Received from Manager (privilege: advanced)
Total subscription create messages received from manager
[-msg-recv-subscription-delete <integer>] - Total Subscription Delete Messages Received from Manager (privilege: advanced)
Total subscription delete messages received from manager
[-msg-recv-unknown <integer>] - Total Unknown Messages Received from Manager (privilege: advanced)
Total unknown messages received from manager
[-msg-send-total <integer>] - Total Messages Sent to Manager (privilege: advanced)
Total messages sent to manager
[-msg-send-manifest-request <integer>] - Total manifest.request Messages Sent to Manager (privilege: advanced)
Total manifest.request messages sent to manager
[-msg-send-baseline <integer>] - Total Baseline Messages Sent to Manager (privilege: advanced)
Total baseline messages sent to manager
[-msg-send-counters <integer>] - Total Counters Messages Sent to Manager (privilege: advanced)
Total counters messages sent to manager
[-msg-send-connection-status <integer>] - Total Connection Status Messages Sent to Manager (privilege: advanced)
Total connection status messages sent to manager
[-msg-send-subscription-status <integer>] - Total Subscription Status Messages Sent to Manager (privilege: advanced)
Total subscription status messages received from manager
[-msg-send-errors <integer>] - Total Error Messages Sent to Manager (privilege: advanced)
Total error messages sent to manager
[-msg-delivery-errors <integer>] - Total Errors Encountered Attempting to Send/receive (privilege: advanced)
Total errors encountered attempting to send/receive
[-msg-send-topicrelay <integer>] - Total ONTAP PubSub Topic Messages Sent to Manager (privilege: advanced)
Total ONTAP PubSub Topic messages sent to manager
[-msg-send-agent-status-details <integer>] - Total agent.status Messages Sent to Manager (privilege: advanced)
Total agent.status Messages sent to Manager
[-msg-connection-total <integer>] - Total Connection Attempts (privilege: advanced)
Total connection attempts
[-msg-connection-errors <integer>] - Total Connection Errors (privilege: advanced)
Total connection errors
[-msg-transport-errors <integer>] - Total Transport Errors (privilege: advanced)
Total transport errors
[-application <text>] - Client Application (privilege: advanced)
Selects the connections that match the supplied application.
[-application-url <text>] - Application URL (privilege: advanced)
Selects the connections that match the supplied application URL.
[-idle-timeout <integer>] - Idle Timeout (in seconds) (privilege: advanced)
AMQP idle timeout. Defaults to 0. If set, the local peer will disconnect if it does not receive AMQP frames within the timeout.
[-address-family {unknown|ipv4|ipv6}] - Address Family (privilege: advanced)
Specify address family.
[-auto-delete-error-minutes {<integer>|-}] - Time to Auto-delete when disconnected (in minutes) (privilege: advanced)
Specify time to live in minutes for cloud agent connection in error state. Connection will be deleted if it stays in error state beyond this time.
cluster-1::> cluster agent connection show
Name          Destination                   State      Application    Use Proxy
cloudinsights amqpws://172.31.50.251        connected  Cloud Insights false
