The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver name-mapping delete
PDF of this doc site
Creating your file...
Your file is ready
Delete a name mapping
The vserver name-mapping delete
command deletes a name mapping.
-vserver <vserver name>
- Vserver-
This parameter specifies the Vserver from which you want to delete the name mapping.
-direction {krb-unix|win-unix|unix-win|s3-unix|s3-win}
- Direction-
This parameter specifies the direction of the name mapping that you want to delete.
-position <integer>
- Position-
This parameter specifies the position of the name mapping that you want to delete. Specify the position as a positive integer.
The following example deletes a name mapping on a Vserver named vs1. The name mapping is from UNIX to Windows and is at position 5.
cluster1::> vserver name-mapping delete -vserver vs1 -direction unix-win -position 5
