volume efficiency inactive-data-compression show
Display volume inactive data compression progress
The volume efficiency inactive-data-compression show command is used to show details of inactive data compression on a volume.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver Name (privilege: advanced)-
This specifies the vserver of the volume.
[-volume <volume name>]- Volume Name (privilege: advanced)-
This specifies the volume on which inactive data compression should be started.
[-progress <text>]- Progress (privilege: advanced)-
Progress of the scan.
[-status <text>]- Status (privilege: advanced)-
Operation on the scan succeeded or failed.
[-failure-reason <text>]- Failure Reason (privilege: advanced)-
If scan failed, the reason of the failure.
[-total-blocks <integer>]- Total Blocks to be Processed (privilege: advanced)-
Total number of blocks which must be processed by inactive data compression scanner.
[-total-processed <integer>]- Total Blocks Processed (privilege: advanced)-
Total number of blocks which are already processed by inactive data compression scanner.
[-percentage <percent>]- Progress (privilege: advanced)-
Scan progress in percentage.
[-cold-blocks-found <integer>]- Number of Cold Blocks encountered (privilege: advanced)-
Number of cold blocks encountered by inactive data compression scanner.
[-compression-done <integer>]- Number of Compression Done Blocks (privilege: advanced)-
Number of blocks on which compression was done.
[-vol-overwrites <integer>]- Number of Vol-Overwrites (privilege: advanced)-
count of logical blocks overwritten in compressed data extents.
[-is-enabled {true|false}]- State of Inactive Data Compression on the Volume (privilege: advanced)-
Is scan enabled on the volume.
[-last-op-start-time <integer>]- Time since Last Inactive Data Compression Scan started (privilege: advanced)-
Time since the last inactive data compression scan op started.
[-last-op-end-time <integer>]- Time since Last Inactive Data Compression Scan ended (privilege: advanced)-
Time since the last inactive data compression scan op ended.
[-last-succ-op-start-time <integer>]- Time since Last Successful Inactive Data Compression Scan started (privilege: advanced)-
Time since the last successful inactive data compression scan op started.
[-last-succ-op-end-time <integer>]- Time since Last Successful Inactive Data Compression Scan ended (privilege: advanced)-
Time since the last successful inactive data compression scan op ended.
[-average-run-time <integer>]- Average run time for Inactive Data Compression Scan (privilege: advanced)-
Average runtime of inactive data compression.
[-threshold-days <integer>]- Inactive data compression scan threshold days value (privilege: advanced)-
Threshold days value for inactive data compression scan. Valid values for this option range from
-threshold-days-minto-threshold-days-max. [-threshold-days-min <integer>]- Inactive data compression scan threshold minimum allowed value. (privilege: advanced)-
Minimum allowed value in threshold days for inactive data compression scan. Valid values for this option range from
1to-threshold-days-max. [-threshold-days-max <integer>]- Inactive data compression scan threshold maximum allowed value. (privilege: advanced)-
Maximum allowed value in threshold days for inactive data compression scan. Valid values for this option range from
-threshold-days-minto60. [-read-history-window-size <integer>]- Time window(in days) for which client reads data is collected for tuning. (privilege: advanced)-
Client read history window. Valid values for this option range from
1to60. [-tuning-enabled {true|false}]- State of auto-tuning of Inactive data compression scan on volume. (privilege: advanced)-
Auto-tuning state of inactive data compression scan.
[-compression-algorithm {lzopro|zstd|zlib}]- Inactive data compression algorithm (privilege: advanced)-
Inactive data compression algorithm.
[-scan-mode {default|compute_compression_savings|extended_recompression}]- Mode of Inactive data compression scan (privilege: advanced)-
Mode of the Inactive data compression scanner.
[-phase1-l1s-processed <integer>]- Phase1 level1s Processed (privilege: advanced)-
Phase1 number of L1s processed by inactive data compression scanner.
[-phase1-lns-skipped <text>,…]- Phase1 lns skipped (privilege: advanced)-
Phase1 number of indirect blocks skipped by inactive data compression scanner.
[-phase2-total-blocks <integer>]- Phase2 Total Blocks to be Processed (privilege: advanced)-
Phase2 number of total blocks which must be processed by inactive data compression scanner.
[-phase2-blocks-processed <integer>]- Phase2 Blocks Processed (privilege: advanced)-
Phase2 number of blocks processed by inactive data compression scanner.
[-repacked-blocks <integer>]- Number of Repacked Blocks (privilege: advanced)-
Number of cold blocks repacked by inactive data compression scanner in extended-recompression mode.
The following example displays details about the inactive data compression on volume "vol1":
cluster:::> volume efficiency inactive-data-compression show -vserver vs1 -volume vol1
Volume: vol1
Vserver: vs1
Is Enabled: true
Progress: IDLE
Status: SUCCESS
Compression Algorithm: lzopro
Failure Reason: -
Total Blocks: -
Total Blocks Processed: -
Phase1 L1s Processed: -
Phase1 Lns Skipped: -
Phase2 Total Blocks: -
Phase2 Blocks Processed: -
Percentage: -
Number of Cold Blocks Encountered: -
Number of Repacked Blocks: -
Number of Compression Done Blocks: -
Number of Vol-Overwrites: -
Time since Last Inactive Data Compression Scan Started(sec): -
Time since Last Inactive Data Compression Scan Ended(sec): -
Time since Last Successful Inactive Data Compression Scan Started(sec): -
Time since Last Successful Inactive Data Compression Scan Ended(sec): -
Average runtime of Inactive Data Compression(sec): -
Tuning Enabled: true
Threshold: 14
Threshold Upper Limit: 21
Threshold Lower Limit: 14
Client Read history window: 14
