security tpm show
Display the status of TPM
This command displays information about the status of the Trusted Platform Module(TPM) device. By default, this command displays the following information:
Node name
Availability of the device
State of the device, if available
Firmware version
Firmware upgrade counter
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Selects the nodes that match this parameter value
[-is-available {yes|no}]
- Is TPM Available?-
Selects the nodes that match this parameter value.
yes - The TPM device is mounted and available.
no - The node does not support a TPM.
[-is-active {yes|no}]
- Is TPM Active?-
yes - The TPM device is available and active.
no - if
-is-available
parameter isyes
, the TPM device is mounted and available but is not responding to TPM commands.
[-version <text>]
- Firmware Version-
Selects the nodes that match this firmware version.
[-upgrade-count <integer>]
- Firmware Counter-
Selects the nodes that match the given number of firmware upgrade tries left.
[-sym-key-size <integer>]
- Size of Primary Symmetric Key-
Selects the nodes that match the given symmetrice key size for the primary symmetric key.
cluster1::> security tpm show Firmware Firmware Node Available? Active? Version Counter ---------------- ---------- ------- -------- -------- node1 yes yes 2.5 64 node2 yes yes 2.5 64 2 entries were displayed.
