Command reference
security tpm show
Display the status of TPM
This command displays information about the status of the Trusted Platform Module(TPM) device. By default, this command displays the following information:
  • Node name
  • Availability of the device
  • State of the device, if available
  • Firmware version
  • Firmware upgrade counter
  • Manufacturer Id
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects the nodes that match this parameter value
[-is-available {yes|no}] - Is TPM Available?
Selects the nodes that match this parameter value.
  • yes - The TPM device is mounted and available.
  • no - The node does not support a TPM.
[-is-active {yes|no}] - Is TPM Active?
  • yes - The TPM device is available and active.
  • no - if -is-available parameter is yes , the TPM device is mounted and available but is not responding to TPM commands.
[-version <text>] - Firmware Version
Selects the nodes that match this firmware version.
[-upgrade-count <integer>] - Firmware Counter
Selects the nodes that match the given number of firmware upgrade tries left.
[-sym-key-size <integer>] - Size of Primary Symmetric Key
Selects the nodes that match the given symmetrice key size for the primary symmetric key.
[-manufacturer <text>] - Manufacturer Id
Displays the TPM Manufacturer Id.
cluster1::> security tpm show
                                      Firmware  Firmware
Node             Available?  Active?  Version   Counter  Manufacturer
node1            yes         yes      2.5       64       IFX
node2            yes         yes      2.5       64       IFX
2 entries were displayed.
