vserver peer suspend
Suspend a Vserver peer relationship
The vserver peer suspend command suspends the Vserver peer relationship between two Vservers.
-vserver <vserver>- Vserver Name-
Specifies name of the local Vserver for which you want to suspend the Vserver peer relationship.
-peer-vserver <vserver>- Peer Vserver Name-
Specifies name of the peer Vserver for which you want to suspend the Vserver peer relationship.
[-force <true>]- Force Suspend-
Suspends the Vserver peer relationship even if the remote cluster is not accessible due to, for example, network connectivity issues.
The following example illustrates how to suspend the Vserver peer relationship between two Vservers lvs1.example.com residing on cluster1 , and pvs1.example.com residing on cluster2 .
cluster1::> vserver peer suspend -vserver lvs1.example.com -peer-vserver pvs1.example.com
